3.1 & 3.2 Extensions Database 3.1 / 3.2Referrals
Referrals
Extension Name: Referrals
Allows members to refer others.
As requested by an0ther23
dmzx/Referrals
- Code update for 3.3.x
Code update admin_controller.
Twig update.
Added controllers.
Code update.
Code update.
Fix double entry.
Code update
Code update
Extension Download: Download-linkReferral v1.0.6 Installation:
  2. Unzip the downloaded release, and change the name of the folder to `referral`.
  4. Copy the `referral` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/referral/composer.json
  6. Look for `Referrals` under the Disabled Extensions list, and click its `Enable` link.
killfrenzy
Re: Referrals
Post by killfrenzy »
What do you mean allow members to refer others? Is that registration form has referral box?
Visit my blog http://androidcribs.com Androidcribs.comAndroidcribs Image
killfrenzy
Re: Referrals
I got an error once in registration
General Error
SQL ERROR [ mysqli ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 3 [1064]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
P
Re: Referrals
killfrenzy
Re: Referrals
Yes sir already fixed now. Thanks..btw can you explain how it works? Where can we put referral? I can't see in registration form. :D
Re: Referrals
:rolling:
Re: Referrals
martin wrote: 14 Mar 2016, 10:37 :rolling:
:rolling:
chaterzhost
    Windows 8.1 Firefox
Re: Referrals
Post by chaterzhost »
So many thanks dear Dmzx
that what i'm looking for
really liked all you work Ultimate point , topic author .... now you add special and unique ref extension
no one update or create ref ext for phpbb 3.1 except you
now i should join to donator group :eusa_dance: :mml:
thanks again
regards!
Re: Referrals
Maybe an option to add the contest on board3 portal? :eusa_dance:
chaterzhost
Re: Referrals
Just translate it to arabic :mml: Download-linkarabic there are a bug : if admin check yes from ACP for Display top 5 referrers on board index and Display referral contests on board index
and didnt create a contest will see an error like this
to avoid this error and if you dont want to start a contest just set NO for :
-Display top 5 referrers on board index
and
-Display referral contests on board index
thanks again Dmzx
regards!
Re: Referrals
Contest works perfect on the index.
Can you upload your files here pls as i cant download from your site as i cant read a thing,
Re: Referrals
chaterzhost wrote: 16 Mar 2016, 03:38 to avoid this error and if you dont want to start a contest just set NO for :
and
What is you default time setting?
chaterzhost
    Windows 8.1 Firefox
Re: Referrals
martin wrote: 16 Mar 2016, 10:11 Contest works perfect on the index.
hi
what i mean if admin didnt start a contest he should set NO for
Display top 5 referrers on board index and Display referral contests on board index drom ACP
i upload the file and add download bbcode [down load=pu rple]Download-link [/down load]to it but didnt work
it fix it buy the admin thanks
dmzx wrote: 16 Mar 2016, 10:28
and
server time ! like this d M Y, H:i
however now i'm adding a banner section where admin can add banners and html code and bbcode like this one
Re: Referrals
The Display top 5 is overall top 5 for refferals and has nothing the do with the contest.
For the download link look in the correct topic, not this one and place there your question.
And the banner you can place in off topic.
We keep then the Topics clear and separate otherwise no one can find anything any more.
killfrenzy
Re: Referrals
After updating 1.0 to 1.01 I got this error in homepage.
Fatal error: Uncaught exception 'Exception' with message 'DateTime::__construct(): Failed to parse time string (@) at position 0 (@): Unexpected character' in /home/frenzydgreat/public_html/phpbb/datetime.php:50 Stack trace: #0 /home/frenzydgreat/public_html/phpbb/datetime.php(50): DateTime->__construct('@', Object(DateTimeZone)) #1 /home/frenzydgreat/public_html/phpbb/user.php(728): phpbb\datetime->__construct(Object(phpbb\user), '@', Object(DateTimeZone)) #2 /home/frenzydgreat/public_html/ext/dmzx/referral/event/listener.php(200): phpbb\user->format_date(NULL) #3 [internal function]: dmzx\referral\event\listener->index_modify_page_title(Object(phpbb\event\data)) #4 /home/frenzydgreat/public_html/vendor/symfony/event-dispatcher/Symfony/Component/EventDispatcher/EventDispatcher.php(158): call_user_func(Array, Object(phpbb\event\data)) #5 /home/frenzydgreat/public_html/vendor/symfony/event-dispatcher/Symfony/Component/EventDispatcher/EventDispatcher.php(46): Symfony\Component\EventDispatcher\EventDispatcher->doDispatch(Arr in /home/frenzydgreat/public_html/phpbb/datetime.php on line 50
