3.2.x Extensions Database 3.2 / 3.3System Info 3.2.x
System Info 3.2.x
Extension Name: System Info 3.2.x
phpBB 3.2 extension that will add System Info to your board index.
System, Board version, Server Uptime and Average load.
Demo:
System Info 3.2.x v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `systeminfo`.
  4. Copy the `systeminfo` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/systeminfo/composer.json
  6. Look for `System Info` under the Disabled Extensions list, and click its `Enable` link.
zardos
Re: System Info 3.2.x
Post by zardos »
Thank you very much for all these extension and 3.2 great work :tumbsyes: :beers:
one problem with this extension when i install it.
Fatal error: Call to undefined function dmzx\systeminfo\event\sys_getloadavg() in C:\Program Files\Ampps\www\ext\dmzx\systeminfo\event\listener.php on line 49
Hope this helps, all other ext for 3.2 work fine.
Thanks zardos
zardos wrote: 01 Mar 2016, 20:05 Thank you very much for all these extension and 3.2 great work :tumbsyes: :beers:
Thanks zardos
Is your server linux or windows?
talonos
Post by talonos »
i think it might be Macintosh 128K lol
Board3 mods/extensions available/created by Talonos @ http://pretereo-stormrage.co.uk
talonos wrote: 01 Mar 2016, 20:12
Yes local lol :lol:
zardos
Post by zardos »
Hi m8, i use Ammps 3.4 local its linux.
This will fix your issue
//$load			= sys_getloadavg();
	$os				= php_uname('s') . ' ' . php_uname('r');
	'UPTIME_DAYS'			=> $daysindex,
	'UPTIME_HOURS'		 => $hoursindex,
	'UPTIME_MINS'			=> $minsindex,
	'UPTIME_SECS'			=> $secsindex,
	//'AVG_LOAD0'			=> $load[0],
	//'AVG_LOAD1'			=> $load[1],
       //'AVG_LOAD2'			=> $load[2],
	'PHP_OS'				=> $os,
Load works on MOST linux distros
windows no mac prob not most linux yes if dubug line 49 shows comment out like above.
zardos
Post by zardos »
Thanks Martin, new it would be Ammps :lol:
dmzx Thanx U very Much :tumbsyes:
System Info 3.2.x - Dutch translation.zip
This information is presented for everyone? Really? Seems to be the easiest way to help hackers with destroying the server... :lol:
Or are there permissions for groups?
Scanialady wrote: 05 Mar 2016, 10:58 This information is presented for everyone? Really? Seems to be the easiest way to help hackers with destroying the server... :lol:
Its now only added <!-- IF not S_IS_BOT and S_USER_LOGGED_IN --> but you can hide if needed with extra statement.
Anders
Post by Anders »
Martins fix did make it show but now i get this it dont count and thats same as welcome on index
System: Windows NT 6.2 • Board version: 3.2.0-b2
Server Uptime: 0 days, 0 hours, 0 minutes and 0 seconds • Average load: • •
Only works on linux systems.
all4phone
Post by all4phone »
Just downloaded and checked on fresh phpbb 3.2.0-RC1 version (localhost)
This error occurred:
Fatal error: Call to undefined function dmzx\systeminfo\event\sys_getloadavg() in C:\xampp\htdocs\phpBB32\ext\dmzx\systeminfo\event\listener.php on line 49
49 line of listener.php
martin wrote: 22 Apr 2016, 13:00 Only works on linux systems.
