3.2.x Extensions Database 3.2 / 3.3Live time clock 3.2.x
Extension Name: Live time clock 3.2.x
Will add live time clock in navbar.
Live time clock 3.2.x v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `livetimeclock`.
  4. Copy the `livetimeclock` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/livetimeclock/composer.json
  6. Look for `Live time clock` under the Disabled Extensions list, and click its `Enable` link.
Re: Live time clock 3.2.x
dmzx and martin Thanx U :tumbsyes:
HemiDart
Post by HemiDart »
Great extension thanks DMZX & Martin.
:wall: I need to get rid of the clock below the header and can not find the code I need to change new at phpBB and its probably right in my face I just can not find it any help would be appreciated.
Hemi
HemiDart wrote: 16 Feb 2017, 23:36 Great extension thanks DMZX & Martin.
Hemi
Delete these lines https://github.com/phpbb/phpbb/blob/mas ... html#L3-L4 and clear cache.
HemiDart
Post by HemiDart »
Thank You :eusa_dance:
K3JAE
Post by K3JAE »
Where can one change the color of the font in this extension. It is currently the default blue... and looks a bit strange on my page which is a shade of brown to tan. Any help would be appreciated. :eyes2:
Ext/dmzx/livetimeclock/styles/prosilver/template/liveclock.js
find this var myfont_color = "#4C5D77"; your find other settings in it too.
dwattel
Post by dwattel »
I installed and activated the LTC but it only showes on the login page, after logging in the LTC is gone.
The possible ext. that is blocking the TLC could be "Welcome Back", after disabling the ext. the LTC is back.
How can I get the LTC working with the ext. "Welcome Back" enabled?
Not knowing the welcome back ext it sounds like there both using the same event name i would chat one to another name.
K3JAE
Post by K3JAE »
martin wrote: 07 Mar 2017, 13:38 ext/dmzx/livetimeclock/styles/prosilver/template/liveclock.js
Go figure.. never thought to look in the .js file. Thanks Martin.. Color change made and now looks all good!! :mml:
Gio
Post by Gio »
How to let the clock show up in dutch?
Gio wrote: 25 May 2017, 00:59 how to let the clock show up in dutch?
I see no language file so I would guess changing the words in liveclock.js also. All tho everyone will see it in dutch.
Should there be a language file added to this extension? :whistl:
How did Jaantje do this? Image
Sniper_E wrote: 25 May 2017, 04:41
Maybe nice option o add indeed :wink:
Gio
Post by Gio »
dmzx wrote: 25 May 2017, 08:27
:mml: :thumbup:
dmzx wrote: 16 Feb 2017, 23:39
Hemi
Hello together.
Where i can find the lines to delete "Your last activity at ....." at the right corner
Thx Jan
