3.2.x Extensions Database 3.2 / 3.3Total Active Extensions 3.2.x
Extension Name: Total Active Extensions 3.2.x
Special Thanks to: martin
This extension shows total active extensions on index.
Total Active Extensions 3.2.x v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `totalavtiveext`.
  4. Copy the `totalavtiveext` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/totalavtiveext/composer.json
  6. Look for `Total Active Extensions` under the Disabled Extensions list, and click its `Enable` link.
Re: Total Active Extensions 3.2.x
dmzx and martin Thanx U
Total Active Extensions 3.2.x - Dutch translation.zip
infspirit
Post by infspirit »
Translate for spanish
:wink:
awr
    Mac OS X Safari
Post by awr »
Turkish language pack
tr.zip
eunaumtenhoid
Post by eunaumtenhoid »
Brazilian Portuguese translation
https://github.com/phpBBTraducoes/totalavtiveext
Xxxbennyxxx
Post by Xxxbennyxxx »
This no longer works in 3.3 Will there be another update?
Xxxbennyxxx
Is there no update for this extension yet?
Warlock75
Post by Warlock75 »
Russian language pack
ru.zip
BBBenj
Post by BBBenj »
Hi!
Is there a way to have a list of these extensions, please? Or is there another extension that does so?
Thanks.
stone23
Post by stone23 »
BBBenj wrote: 10 Jan 2022, 17:59 Or is there another extension that does so?
Hi, yes, this extension Active Extensions List make it. :wink:
BBBenj
    Linux Opera
Post by BBBenj »
Hi Stone23,
I already tried it and it doesn't seem to work with phpBB 3.3.5...
stone23
Post by stone23 »
It works with 3.3.5, it is installed on my forum in 3.3.5 and php 8
If in doubt see this section on the index page to see if it works on latest versions.
BBBenj
Post by BBBenj »
Hi!
stone23 wrote: 13 Jan 2022, 20:16 it works with 3.3.5, it is installed on my forum in 3.3.5 and php 8
You should check the message I posted there:
https://www.phpbb.com/customise/db/exte ... pic/234566
I tried again, but still no luck.
phpBB 3.3.5, PHP 7.3 (fixed by OVH).
And the screenshot:
