Extensions Database 3.1 / 3.2 ⇒ 3.1.x Feed Hover
3.1.x & 3.2.x
9 given 1
Feed Hover
Extension Name: Feed Hover
Feed hover effect.
Video:
https://www.youtube.com/watch?v=tx6GgOXjfX0
  2. Unzip the downloaded release, and change the name of the folder to `feedhover`.
  4. Copy the `feedhover` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/feedhover/composer.json
  6. Look for `Feed Hover` under the Disabled Extensions list, and click its `Enable` link.
zardos
Re: Feed Hover
Post by zardos »
DM does this not need to be enabled within the html- forumlist_body before it works, this is what i did.
<!-- IF S_ENABLE_FEEDS and forumrow.S_FEED_ENABLED -->[color=red]<!--[/color] <a class="feed-icon-forum" title="{L_FEED} - {forumrow.FORUM_NAME}" href="{U_FEED}?f={forumrow.FORUM_ID}"><img src="{T_THEME_PATH}/images/feed.gif" alt="{L_FEED} - {forumrow.FORUM_NAME}" /></a>[color=red] -->[/color]<!-- ENDIF -->
I had to delete the red tags for the feeds to show.
tamarin
Re: Feed Hover
Post by tamarin »
Thank you for the extension.
But it don't work.
Help me please.
Thx.
zardos
Re: Feed Hover
Post by zardos »
Remove the tags in the html file as above, it then works perfect. where it says color=red remove <!-- and near the endif --> :thumbup:
1 given 1
Re: Feed Hover
blaaaa blaaaaa blueeeeeeeeeee yup they work
[color=#FF0000]blaaaa[/color] [color=#808040]blaaaaa[/color]  [color=#4000BF]blueeeeeeeeeee[/color]
zardos
Re: Feed Hover
Post by zardos »
<!-- IF S_ENABLE_FEEDS and forumrow.S_FEED_ENABLED --><!-- <a class="feed-icon-forum" title="{L_FEED} - {forumrow.FORUM_NAME}" href="{U_FEED}?f={forumrow.FORUM_ID}"><img src="{T_THEME_PATH}/images/feed.gif" alt="{L_FEED} - {forumrow.FORUM_NAME}" /></a> --><!-- ENDIF -->
<!-- IF S_ENABLE_FEEDS and forumrow.S_FEED_ENABLED -->[color=#FF0000]<!--[/color] <a class="feed-icon-forum" title="{L_FEED} - {forumrow.FORUM_NAME}" href="{U_FEED}?f={forumrow.FORUM_ID}"><img src="{T_THEME_PATH}/images/feed.gif" alt="{L_FEED} - {forumrow.FORUM_NAME}" /></a> [color=#FF0000]-->[/color]<!-- ENDIF -->
:wink:
tamarin
Re: Feed Hover
Post by tamarin »
zardos wrote: 29 Jul 2016, 23:45 Remove the tags in the html file as above, it then works perfect. where it says color=red remove <!-- and near the endif --> :thumbup:
color=#FF0000sdfsdfsdfsdf/color. DMZX=Colour tags do not work.
Did you write this to me?
:wall:
zardos
Re: Feed Hover
Post by zardos »
Yes for you tamarin
Remove the red tags below in forumlist_body.html the above ext will then work.
tamarin
Re: Feed Hover
Post by tamarin »
zardos wrote: 30 Jul 2016, 21:13 Yes for you tamarin
Thank you zardos.
I did as you said.
Now it is showing.
But it is not working as it should RSS.
Where can I see how this extension work?
Thx.
zardos
Re: Feed Hover
Post by zardos »
Hi tamarin, sorry but i know nothing about RSS feed, i could only show you how to enable the feed for the above extension to work, but maybe dmzx or martin or others may help with RSS.
