Extensions Database 3.1 / 3.2 ⇒ 3.1.x Hide Index Info
3.1.x & 3.2.x
15 given 2
Hide Index Info
Extension Name: Hide Index Info
Hide Index Info for guests (who is online, birthdays and statistics)
Request here viewtopic.php?p=6840#p6840
[travis]dmzx/Hide-Index-Info[/travis]
  2. Unzip the downloaded release, and change the name of the folder to `hideindexinfo`.
  4. Copy the `hideindexinfo` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/hideindexinfo/composer.json
  6. Look for `Hide Index Info` under the Disabled Extensions list, and click its `Enable` link.
Darby_Crash
Re: Hide Index Info
Post by Darby_Crash »
Work great on phpBB 3.1.7-pl1. :thumbup:
Evolution is a process too slow to save my soul
tamarin
Re: Hide Index Info
Post by tamarin »
dmzx, thank you for the extension.
Very nice extension!
Can you also hide the plugin Top Five?
Thank you in advance.
lopoto
0 given 2
Re: Hide Index Info
Post by lopoto »
Working well ,
and show double statistic ? :yikes:
phpBB 1.8
15 given 2
Re: Hide Index Info
lopoto wrote: 02 Mar 2016, 22:43 working well ,
phpBB 1.8
PM me your link of your board.
all4phone
Re: Hide Index Info
Post by all4phone »
Works well for me :tumbsyes:
It's possibility to add Activity over the last 24 hours to this ext?
15 given 2
Re: Hide Index Info
all4phone wrote: 06 Jun 2016, 13:07 Works well for me :tumbsyes:
Is that an extension?
all4phone
Re: Hide Index Info
Post by all4phone »
Yes, It is.
[ Post made via iPhone ] Image
15 given 2
Re: Hide Index Info
all4phone wrote: 06 Jun 2016, 20:08 Yes, It is.
Copy the html code from that extension to the index_body_stat_blocks_after.html in the hideindexinfo extension.
Between the <!-- IF S_DISPLAY_ONLINE_LIST and S_USER_LOGGED_IN -->
all4phone
Re: Hide Index Info
Post by all4phone »
Yeah, it was a good solution (removed and pasted). It works perfectly, as I intented, many thanks for your help :tumbsyes:
15 given 2
Re: Hide Index Info
all4phone wrote: 06 Jun 2016, 21:35 Yeah, it was a good solution (removed and pasted). It works perfectly, as I intented, many thanks for your help :tumbsyes:
taledus
Re: Hide Index Info
Post by taledus »
I had an issue with using this extension and displaying the Statistics section twice when using Statistics on Index extension. I commented out the first Statistics section since the information there already displayed on Statistics on Index.
/ext/dmzx/hideindexinfo/styles/prosilver/template/event/index_body_stat_blocks_after.html
<!-- IF NEWEST_USER and S_USER_LOGGED_IN -->
	<div class="stat-block hidestatistics">
		<h3>{L_STATISTICS}</h3>
		<p>
			<!-- EVENT index_body_block_stats_prepend -->
			{TOTAL_POSTS} &bull; {TOTAL_TOPICS} &bull; {TOTAL_USERS} &bull; {NEWEST_USER}
			<!-- EVENT index_body_block_stats_append -->
		</p>
	</div>
It can probably be deleted though.
15 given 2
Re: Hide Index Info
Yes combination of extensions can lead to double code.
Delete or comment out 1 of the codes. :wink:
Antaka
Re: Hide Index Info
Post by Antaka »
Hi Dmzx
The display of statistics is duplicated on the index
Cordially
1 given 2
Re: Hide Index Info
Antaka wrote: 02 Sep 2016, 09:22 Hi Dmzx
Cordially
read here viewtopic.php?p=11200#p10269
