3.1.x Extensions Database 3.1 / 3.2 ⇒ [RC] Tables bbCode
[RC] Tables bbCode
Extension Name: Tables
Extension Version: 2.0.8
Author: Sniper_E
Special thanks to: All of you for helping me test this out.
Extension Description: Inserts a table block in your post.
Completely style dependent to work in any dark or light style. Posting Buttons and ABBC3 ready.
Installation: Copy contents from download to ext/sniper/tables/ directory - Enable in ACP
Update: Disable, Delete data, Delete old BBCodes, Delete server files, Upload new files, Enable in ACP, Clear cache
Enjoy!
Author: Sniper_E
Enjoy!
Re: Tables bbCodes
Will check it
[ Post made via Samsung Galaxy S4 ]
tamarin
Re: Tables bbCodes
Thank you very much for the very necessary extension.
Is it possible to implement such an idea, see. Attachment?
Re: Tables bbCodes
Yes tamarin after looking at the WYSIWYG HTML editor I thought I would see if I could make the drop down selection menu similar to that. Maybe make it bring up the Preview after you make your selection.
I think that had a selection of 10 rows and 10 columns. Do you think this extension need that many selections also?
tamarin
Re: Tables bbCodes
I think 10 rows and 5 columns will suffice.Sniper_E wrote: 15 Jan 2016, 04:48 Yes tamarin after looking at the WYSIWYG HTML editor I thought I would see if I could make the drop down selection menu similar to that. Maybe make it bring up the Preview after you make your selection.
Thank you in advance.
Re: Tables bbCodes
[ Post made via Samsung Galaxy S5 Active ]
Fast_Eddie
Re: Tables bbCodes
Has anyone tried to see if this ext. can parse BBcode and smiles? IT DOES !!!
I think i'm getting the hang of it
Fast_Eddie
Re: Tables bbCodes
Think i found a problem with this extension. On my test board when enabled it makes the color selection bar HUGE. When i disable it the bar goes back to normal size.
It also messed up profile display (no idea why) I did run a backup before I enabled it. So after I just did a RESTORE everything is good now.
Re: Tables bbCodes
I don't have that problem with my install. Of course I did insert tables copied out of subsilver2 when I threw this together. Maybe there is a conflict with the added classes. I'll look at it and use the table codes from prosilver and there should not be any conflict. But eventually I will be moving this code over <div>s so none of that will matter.
I'll look into it.
I'll look into it.
Fast_Eddie
Re: Tables bbCodes
Ok cool! I had the same problem with the plain prosilver and Aero styles. Also would there be a way to center a table on the page? I tried the center BBcode , and it centered text in the cells. But not the table it's self. I figured out how to change the cell sizes also :) I'm really liking this extension! It' a lot more flexible than I thought at first glance. Don't laugh but I was almost able to make a football square for the super bowl with it. (22x34)
Fast_Eddie
Re: Tables bbCodes
They work fine together on my test board. The only bug '' I '' know of is it changes the size of the color selection bar when posting a msg.This one doesn't work well with Advanced BB-Code enabled??
OK, I have to update this:
On my test board I have the post buttons Ext. installed along with ABC mod. When I disabled the post button ext. The tables Ext. disappeared.
Puchahawa
Re: Tables bbCodes
Try disabling the extension and re-enable it. It's possible they used some of the same info and it got removed when you got rid of the other ext.
nelflucifer
Re: Tables bbCodes
A very useful tool!
English Forums
Fast_Eddie
Re: Tables bbCodes
That was a good idea, but it didn't work. I also tried deleting data for tables and re-install. That did no good either. So maybe Tables won't work with ABC ?Try disabling the extension and re-enable it. It's possible they used some of the same info and it got removed when you got rid of the other ext.
