3.1.x Extensions Database 3.1 / 3.2Tabbed Profiles
Tabbed Profiles
Extension Name: Tabbed Profiles
Divides the members profile into separate tabs
[travis]dmzx/Tabbed-Profiles[/travis]
  2. Unzip the downloaded release, and change the name of the folder to `tabprofile`.
  4. Copy the `tabprofile` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/tabprofile/composer.json
  6. Look for `Tabbed Profiles` under the Disabled Extensions list, and click its `Enable` link.
Re: Tabbed Profiles
Thanks, looks a lot neater :)
TWEagle
Re: Tabbed Profiles
Post by TWEagle »
It doesn't work on my test site:
http://try.offorum.eu/memberlist.php?mo ... ile&u=6378
nelflucifer
Re: Tabbed Profiles
Post by nelflucifer »
When you enable Tabbed Profiles not working View profile. Who looked at my profile. Tell me what to do? Version of phpbb3.1.6 EN Both extensions from YOU! dmzx :question: :question: :wall:
English Forums
Anuj Dhawan
Re: Tabbed Profiles
Post by Anuj Dhawan »
It works well but it does not show up the "LAST TOPICS VISITED" and "Member Profile Views:", if activated. Any suggestion for that please?
nelflucifer
Re: Tabbed Profiles
It's about compatibility with Tabbed Profiles View profile. When you turn on Tabbed Profiles is View profile. Maybe works but I don't see who looked my profile/ visit. On your site it works. I don't have. Only found out because we had to disable View profile/Visitor to ascertain the reasons. Theme / AERO
Re: Tabbed Profiles
nelflucifer wrote: 20 Jan 2016, 09:55 when you enable Tabbed Profiles not working View profile. Who looked at my profile. Tell me what to do? Version of phpbb3.1.6 EN Both extensions from YOU! dmzx :question: :question: :wall:
See viewtopic.php?p=6823#p6823
cisco007
Re: Tabbed Profiles
Post by cisco007 »
I see you seem to have this installed on here DMZX, did you have to alter anything for it to work on phpbb version 3.2.x?
zardos
Re: Tabbed Profiles
Post by zardos »
Hi all, a problem with this ext. if i install members profile views it works perfect, untill i install tabbed profiles, then members profile views disappear. just to check i uninstalled tabbed profile views and profile views was back again.
Thanks.
Anuj Dhawan
Re: Tabbed Profiles
That's the default behavior, AFAIK .There are manual ediys needed to get what you want. Please search the forum.
Re: Tabbed Profiles
See viewtopic.php?f=51&t=1510
[ Post made via Samsung Galaxy S4 ] Image
zardos
Re: Tabbed Profiles
Post by zardos »
Cool thanks. :tumbsyes:
cisco007
Re: Tabbed Profiles
Post by cisco007 »
cisco007 wrote: 04 Mar 2016, 02:09 i see you seem to have this installed on here DMZX, did you have to alter anything for it to work on phpbb version 3.2.x?
Re: Tabbed Profiles
cisco007 wrote: 14 Mar 2016, 01:37
See Tabbed Profiles 3.2.x :wink:
Kinsman
Re: Tabbed Profiles
Post by Kinsman »
Is it possible to create extra tabs, or we can only move stuff around between the existing three tabs?
