Extensions Database 3.1 / 3.2 ⇒ 3.1.x Ultimate Points Extension
3.1.x & 3.2.x
15 given 2
Author: dmzx & posey
[travis]dmzx/Ultimate-Points-Extension[/travis]
Changed PM code
Move more to functions
Changed migration
Changed version check
Add lottery winner on index
Add link in profile/viewtopic for robbery
Updated css
Fix lottery bug
Changed Bank payout
Code update
Added avatars index/userlist
Added new UCP option
Code update
Code update
Couple of things added:
  • Transfer Fee
  • Modify Points, can now select Set, Add, Substract
  • Points List, show all users with their points (resp.)
  • UCP Panel
  • Log Entries
    • Robbery
    • Bank Balance Edit
    • User Points Edit
    • Bank Interest Pay Out
  • Notifications
    • Bank Edit
    • Random Bonus Points
  • Forum Cost Attachment
    • Show cost in-line with attachment
  • Forum Cost Topic
  • Forum Cost Post
  • Permissions
    • Now in seperate 'Ultimate Points' tab
    • Pay for new Topic
    • Pay for new Post
[CHANGED]
  • Notification ID moved from points_values table to config
[REMOVED]
  • values table: robbery_notify_id
Requirements:
  • PHP >= 5.3.3
  • phpBB >= 3.1.0
3.0 MOD Authors:
This is a port of the 3.0 MOD: Ultimate Points, written by: femu & Wuerzi
Features:
  • Points System
    • Receive points per new topic/post or edit (Able to set per forum)
    • Receive points per words/characters in the post
    • Receive points for attachments/polls
    • Receive points for registering
    • Lose points per warning
    • Pay points per attachment download (Able to set per forum)
    • Users can Transfer points to other users
  • Bank
    • Personal Bank Name
    • Interest Rate
    • Interest Pay-out time
    • Withdrawal fee
    • Banking fee
  • Lottery
    • Personal Lottery Name
    • Multiple Tickets
    • Jackpot Win Rate and base amount
    • Private Message to the Winner
    • Complete history of previous lottery results!
  • Robbery
    • Users can rob other users
    • Can set chance success of a robbery
    • Notifications sent to the person who got robbed
    • Penalty on a failed robbery
  • User Guide
    • Detailed explanation on how everything works, so make sure to check for the most common questions and their respective answers!
  1. Download the latest release
  2. Create a new folder in the /ext/ directory, named: dmzx (If it doesn't exist already)
  3. Create a new folder in /ext/dmzx/ named ultimatepoints
  4. Copy the contents from the Ultimate-Points-Extension-master folder from your download into
    /ext/dmzx/ultimatepoints/
  5. The main extension class should now be at: root/ext/dmzx/ultimatepoints/composer.json
  6. Nagivate in the Administration Control Panel (ACP) to Customise -> Manage Extensions
  7. Look for Ultimate Points Extension in the Disabled Extensions list and click Enable!
Download:
The Good
Re: Ultimate Points Extension
Post by The Good »
One of the best extension.... !!!
necrowolf
Post by necrowolf »
I was real excited when I found this but I can't get it to work. It's there and turned on under Customize tab but under Extensions tab when I click enable and then submit I get totally logged out of my forum completely. Tried 3 times so I really have no idea where to start to find out what's wrong.
15 given 2
necrowolf wrote:I was real excited when I found this but I can't get it to work. It's there and turned on under Customize tab but under Extensions tab when I click enable and then submit I get totally logged out of my forum completely. Tried 3 times so I really have no idea where to start to find out what's wrong.
Hi and welcome,
What style do you use?
And can you PM me link of your board?
grtz dmzx
necrowolf
Post by necrowolf »
Hi and welcome,
grtz dmzx
Sent link. My first guess would be a conflict with another extension but which one? I have several is the problem. May have to disable them one by one.
15 given 2
The Good
Post by The Good »
Can we have : members lose the point if they havent post per day ...
each day if they dont post new post.. they will lose some points !!
this idea is good for my forum... because I will give access to private forum some members exp: silver member or gold with their earning points... so to keep them active...
also
exp; create new topic = 5point
reply to topic =2
Posey
Post by Posey »
The Good wrote:exp; create new topic = 5point
reply to topic =2
You can already define how much points they earn when making a new topic or post, you can set it in the ACP.
''I'm pretty sure there's a lot more to life than being really, really, ridiculously good looking.
And I plan on finding out what that is.''
posey
The Good
Post by The Good »
reply to topic =2
thanks my friend... for info :thumbup:
15 given 2
The Good
Post by The Good »
Thanks for update...
Zerondar
Post by Zerondar »
Installed it, the points part works perfectly fine,
except i can not get this screen
as it's nowhere to be found
the money part also does not show up in my top bar next to quick links
(i have userranks and pages ext enabled, but even disabling those did nothing)
**edit** works perfectly fine after i renamed the points to something else
Hello, I started a new forum and just installed this extension.
But I see some weird things @ "Transfer".
There are some strange icons in the message field :rolling:
15 given 2
Solidjeuh wrote:Hello, I started a new forum and just installed this extension.
check the id=comment on Ultimate-Points-Extension/points_transfer.html at a37fe445d27df5803e3dc8fc543a6a63f579d056 · dmzx/Ultimate-Points-Extension · GitHub
I have the same:
<dd><textarea id="comment" tabindex="2" class="inputbox" name="comment" cols="50" rows="3" >{COMMENT}</textarea></dd>
And same problem on the prosilver style.. I use PS4 : phpBB • PS4 - Contribution Details
~ Algemeen Forum ~ - Indexpagina
