3.1 & 3.2 Extensions Database 3.1 / 3.2New Topic
New Topic
Extension Name: New Topic
Show the list of forums on the board, the forum selected will be created a new topic.
[travis]dmzx/New-Topic[/travis]
Code update, validation version.
Code update.
Added for registered users only
Added lang file for select option
  2. Unzip the downloaded release, and change the name of the folder to `newtopic`.
  4. Copy the `newtopic` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/newtopic/composer.json
  6. Look for `New Topic` under the Disabled Extensions list, and click its `Enable` link.
Peralta
Re: New Topic
Post by Peralta »
Thank you dmzx :thumbup:
phpBB • Post new topic - Contribution Details
It is not the same but is quite similar...
Re: New Topic
sakkiotto
Re: New Topic
Post by sakkiotto »
Zip damaged?
nelflucifer
Re: New Topic
Post by nelflucifer »
ru.zip
English Forums
sakkiotto
Re: New Topic
Post by sakkiotto »
There is only file languages LOL
sakkiotto
Re: New Topic
Post by sakkiotto »
Can you reupload this extension ? the file is always corrupted :thumbdown:
Re: New Topic
sakkiotto wrote: 29 Feb 2016, 16:11 Can you reupload this extension ? the file is always corrupted :thumbdown:
File uploaded :thumbup:
khurrammunawar
Re: New Topic
Post by khurrammunawar »
Newly registered users , whose posts are subject to approval , can not post a new topic via this extension.
khurrammunawar
Re: New Topic
Bump
Re: New Topic
Re: New Topic
I want to place it somewhere else, so need to remove that "dot" before.
Is it ok to change the code to <div class="responsive-hide" align="right"> ?
This will not break the responsive thing or something else? :eyes2:
Re: New Topic
Where do you want to place it?
in extension is now <li class="right rightside responsive-hide">
Re: New Topic
dmzx wrote: 05 Mar 2017, 20:59 Where do you want to place it?
I placed it in overall_header_navbar_before.html
Re: New Topic
So did you change overall_header_breadcrumbs_after.html to overall_header_navbar_before.html ?
