<span class="qte-attr qte_31_32-qte">3.1.x & 3.2.x</span>
Posts: 6586 Joined: 13 Jan 2014, 21:45
Post
by dmzx » 15 Nov 2015, 23:09
Extension Name: Topic Subscribers
This extension shows the Topic Subscribers in viewtopic as requested here
viewtopic.php?p=5446#p5446
[travis]dmzx/Topic-Subscribers[/travis]
Added avatar
html valid
Code update
Download the latest release.
Unzip the downloaded release, and change the name of the folder to `topicsubscribers `.
In the `ext ` directory of your phpBB board, create a new directory named `dmzx ` (if it does not already exist).
Copy the `topicsubscribers ` folder to `/ext/dmzx/ ` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/topicsubscribers/composer.json
Look for `Topic Subscribers ` under the Disabled Extensions list, and click its `Enable ` link.
Anders
Posts: 80 Joined: 15 Sep 2015, 08:15
Post
by Anders » 16 Nov 2015, 07:42
Thanks for this...looks great ...
but i have problem i cant see what i see here on this image
on my site don't subscribers show up as it does on the image here
and there is subscribers
Posts: 5138 Joined: 06 Apr 2014, 16:12
Post
by martin » 16 Nov 2015, 08:59
What is the link to your board ?
Anders
Post
by Anders » 16 Nov 2015, 09:09
You have PM
Post
by martin » 16 Nov 2015, 09:17
Can you purge the boards cache pls
Anders
Post
by Anders » 16 Nov 2015, 09:18
Done
Post
by martin » 16 Nov 2015, 09:31
Anders
Post
by Anders » 16 Nov 2015, 09:33
Ok then i know thx alot for help
Post
by martin » 16 Nov 2015, 09:35
Anders
Post
by Anders » 16 Nov 2015, 09:42
I have one more question is it possible to make this
i have told every one to thick Subscribe forum but i dont know if every one have done that....
Post
by martin » 16 Nov 2015, 09:48
Anders
Post
by Anders » 16 Nov 2015, 10:06
Post
by martin » 07 Feb 2016, 02:52
Small html5 fix
/ext/dmzx/topicsubscribers/styles/all/template/event/viewtopic_body_footer_before.html
Delete the code in the file and replace with
<!-- IF .subscribers -->
<div class="stat-block responsive-hide">
<h3><a id="subscribers">{L_SUBSCRIBERS}</a></h3>
<p><!-- BEGIN subscribers --><!-- IF not subscribers.S_FIRST_ROW --> • <!-- ENDIF --> <a href="{subscribers.U_PROFILE}">{subscribers.NAME}</a>
<!-- END subscribers --></p>
</div>
why you ask well
<h3><a name="subscribers">{L_SUBSCRIBERS}</a></h3> name= is no longer valid you must use a id so id= is now used.
Post
by dmzx » 07 Feb 2016, 10:50
martin wrote: 07 Feb 2016, 02:52
Small html5 fix
</div>
why you ask well
