3.1.x Extensions Database 3.1 / 3.2 ⇒ Partner Page
9 given 1
Partner Page
Extension Name: Partner Page
Special thanks to: martin & Sniper_E
This extension will add a partner page to your forum, where you can list your partners with a description and a logo.
Check permissions for groups that you want to give access to add or view partner page.
If users add a new partner page the Admin will get a notification and need to activate the new partner page in ACP.
[travis]dmzx/Partner-Page[/travis]
code update
Style update
Css update
Add option in ACP and member upload to add Bg_header.gif of your partner.
  2. Unzip the downloaded release, and change the name of the folder to `partner`.
  4. Copy the `partner` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/partner/composer.json
  6. Look for `Partner Page` under the Disabled Extensions list, and click its `Enable` link.
Re: Partner Page
Thanks Guys :tumbsyes:
1 given 1
Re: Partner Page
Mine has a posh upload button :rolling:
1 given 1
Re: Partner Page
Temp fix for the images to be responsive on mobiles/small screens.
Drag the side of this page martins-place.dyndns.info - Information until the images go away.
dm_partners_body.html
<!-- IF partners.S_IMAGE --><dd><div style="text-align: right;"><a href="{partners.URL}" onclick="window.open(this.href); return false"><img src="{partners.IMAGE}" alt="{partners.SITE}" title="{partners.SITE}" /></a><br /><br /></div></dd><!-- ENDIF -->
<!-- IF partners.S_IMAGE --><dd><div class="responsive-hide" style="text-align: right;"><a href="{partners.URL}" onclick="window.open(this.href); return false"><img src="{partners.IMAGE}" alt="{partners.SITE}" title="{partners.SITE}" /></a><br /><br /></div></dd><!-- ENDIF -->
this
to this
Before any one shouts yes it should be done with css i know but as stated quick fix ans the ext still needs a little work.
9 given 1
Re: Partner Page
1 given 1
Re: Partner Page
Just a few logo's and headbar images.
(oz image does show but linux wont allow it)
userlogo.zip
Re: Partner Page
I get those images straight from the sites I'm adding in my Partners page. But thanks anyways :tumbsyes: .
1 given 1
Re: Partner Page
It's ok to grab the image url and use that but if the site goes offline ??
Myself i would rather host the said images just to keep things tidy looking.
Re: Partner Page
That is an excellent idea. You have changed my mind. I'm set now...
And that works even better because I had to adjust the height of spaceace's bg_header image for it to look right.
I would not be able to do that by linking to his image. I don't care what dmzx says about you... You are a genius.
It looks like you need to extend the height on my bg_header image for the bar to show across the bottom.
And it looks like dm needs to shorten the height on my bg_header image.
Are you two using different padding? Why would they look different? I put my site in at my place and it looks right.
I use padding: 10px; in the .partners-logo class and max-height: 68px; in the img.partners-logo-img class.
1 given 1
Re: Partner Page
Not that it really matters but if you update the ext and for some reason you forget and delete this version you just lost all images as your storing them within an ext (your choice) i'm using this path so the images stay ./images/userlogo/ed.png of course the path needs to be made just a safer way to store/keep the images i think.
:yikes: what does dm say about me ?? did he tell you i have to baby sit him too :rolling:
Same as me
img.partners-logo-img {
   max-width: 500px;
   max-height: 68px;
.icon-partners   {
   background-image: url("./images/icon_partners.gif");
.buttons div.partners-icon {
   width: 96px;
   height: 25px;
.partners-title {
   font-family: Verdana;
   font-size: 1.4em;
   font-weight: bold;
.partners-logo {
   text-align: center;
   background-color: #1464B1;
   padding: 10px;
   border: 1px solid #000000;
   box-shadow: 1px 1px 1px #000;
   -webkit-border-radius: 6px;
   -o-border-radius: 6px;
   -moz-border-radius: 6px;
   border-radius: 6px;
9 given 1
Re: Partner Page
Tell what :question: :wtf:
nelflucifer
Re: Partner Page
Post by nelflucifer »
ru.zip
English Forums
Zockgeier
Re: Partner Page
Post by Zockgeier »
ThX for Extension. :thumbup:
I translated it to German language.
partner_de.zip
Best regards
Zockgeier
Superl
Re: Partner Page
Post by Superl »
Love it thank you the only thing missing for me is to control the order of the partners. wish we could order them in the acp. For now the newest one will be the first one displaying when it should be the other way around.
Edit: Now I see that they are sorted alphabetically, but still be able to order them would be great
9 given 1
Re: Partner Page
