Extensions Database 3.1 / 3.2 ⇒ 3.1.x Sinkship
3.1.x & 3.2.x
15 given 2
Sinkship
Extension Name: Sinkship
Play a little Javascript game sinkship
  2. Unzip the downloaded release, and change the name of the folder to `sinkship`.
  4. Copy the `sinkship` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/sinkship/composer.json
  6. Look for `Sinkship` under the Disabled Extensions list, and click its `Enable` link.
Null
Re: Sinkship
Post by Null »
Translations to Spanish and Portuguese-Brazil: Download sinkship.rar from Sendspace.com - send big files the easy way
15 given 2
Re: Sinkship
Null wrote:Translations to Spanish and Portuguese-Brazil: Download sinkship.rar from Sendspace.com - send big files the easy way
Added :thumbup:
Null
Re: Sinkship
Post by Null »
In github its said "pt-br Spanish translation" but should be "pt-br Portuguese-Brazil translation": Sinkship/language at master · dmzx/Sinkship · GitHub
1 given 2
Re: Sinkship
Broke on mobile must be script in iframe the other games are good
[ Post made via iPhone ] Image
15 given 2
Re: Sinkship
Null wrote:In github its said "pt-br Spanish translation" but should be "pt-br Portuguese-Brazil translation": Sinkship/language at master · dmzx/Sinkship · GitHub
Changed!
nelflucifer
Re: Sinkship
Post by nelflucifer »
Simple and interesting.
ru.zip
English Forums
all4phone
Re: Sinkship
Post by all4phone »
Polish translation v 1.0.0
pl.zip
15 given 2
Re: Sinkship
Thanks both for the translation :thumbup:
mjezek
Re: Sinkship
Post by mjezek »
Czech translation:
cs.zip
Re: Sinkship
German translation
sinkship_1_0_0_dmzx_lang_de.zip
Re: Sinkship
Will this work on 3.2.x?
eumelchen
Re: Sinkship
Post by eumelchen »
for me, the extension runs with phpBB 3.2.1 and PHP 7, but I have another question:
Is there a way to make the extension responsive?
I would be enough if I knew how to display the areas "Computer Fleet" and "Your Fleet" among themselves.
Excuse my bad english, my native language is german.
Greetings Rolf (eumelchen)
eumelchen
Re: Sinkship
Post by eumelchen »
does nobody have an idea what I could do there?
Regards Rolf (eumelchen)
Posey
Re: Sinkship
Post by Posey »
eumelchen wrote: 24 Feb 2018, 10:58 Hello,
It's possible, it's just not a 'clean' way.
in dm_sinkship_body.html change the iframe height to 600.
<iframe frameborder="0" height="600" width="720" scrolling="no" src="{BOARD_URL}ext/dmzx/sinkship/styles/prosilver/template/dm_sinkship_script.html"></iframe>
and in dmzx_sinkship_script:
Find: // document.write
Replace that line all the way to the end with:
// document.write("<br /><br /><center><table><tr><td align=center><p class='heading'>Computer Fleet</p></td><td align=center><p class='heading'>Your Fleet</p></td></tr><tr><td>");
document.write("<br /><br />");
if (window.outerWidth >= 700) { document.write("<center>"); }
document.write("<table><tr><td align=center><p class='heading'>"+languages['Computer_Fleet']+"</p></td>");
if (window.outerWidth >= 700) { document.write("<td align=center><p class='heading'>"+languages['Your_Fleet']+"</p></td></tr><tr><td>"); } else { document.write("</tr><tr><td>"); }
showGrid(true);
document.write("</td>");
if (window.outerWidth < 700) { document.write("</tr><tr><td align=center><p class='heading'>"+languages['Your_Fleet']+"</p></td></tr><tr>"); }
document.write("<td>");
showGrid(false);
document.write("</td></tr></table>");
updateStatus();
setInterval("setStatus();", 500);
// End -->
</script>
</head>
</html>
''I'm pretty sure there's a lot more to life than being really, really, ridiculously good looking.
And I plan on finding out what that is.''
posey
