Extensions Database 3.1 / 3.2 ⇒ 3.1.x [RC] Smilie Signs
3.1.x & 3.2.x
[RC] Smilie Signs
Extension Name: Smilie Signs
Extension Version:
1.0.2
Author: Sniper_E
Special thanks to: dmzx, martin and my main man Puchahawa
Extension Description: Posts an animated smilie holding a sign up with your message.
Extension Download: smiliesigns_1.0.2.zip
  1. Download the latest release and unzip.
  2. In the `ext` directory of your phpBB board, create a new directory named `sniper` (if it does not already exist).
  3. Copy the `smiliesigns` folder to `/ext/sniper/` if done correctly, you'll have the main extension class at (your forum root)/ext/sniper/smiliesigns/composer.json
  4. Navigate in the ACP to `Customise -> Manage extensions`
  5. Look for `Smilie Signs` under the Disabled Extensions list, and click its `Enable` link.
Upgrade:
  1. Disable smiliesigns extension and delete data.
  2. Delete existing sign= BBCode in ACP/Posting tab.
  3. Delete all old files from server.
  4. Upload new 1.0.11 files to server.
  5. Enable smiliesigns extension and clear server cache.
13 given 1
Re: Smilie Signs
Nice one
Re: Smilie Signs
Just installed, but not working
I choose a smiley, but it's not being added in the text field.. nothing happens ..
Midway
Re: Smilie Signs
Post by Midway »
tested, very good
Re: Smilie Signs
Solidjeuh wrote:Just installed, but not working
Thank you for reporting. Do you think you are having a conflict with another bbcode extension?
Let me know what other extension you have installed that uses bbCodes and I will test it.
EDIT: I tell you what... let's just side step this conflict.
I'll change styles/all/template/smiliesigns_posting_editor_buttons.html to prevent conflicts with other bbCode extensions.
First post download updated using this line of codes...
	<select class="gensmall" name="smiliesign" onchange="bbfontstyle('[sign=' + this.form.smiliesign.options[this.form.smiliesign.selectedIndex].value + '', '[/sign]');this.form.smiliesign.selectedIndex = 0;" title="{L_BBCODE_SIGN_HELP}" style="height: 21px;">
[sign=club]That better fix any future problems like this![/sign]
Re: Smilie Signs
Still the same problem..
I use:
Extension that use Bbcodes:
Board Announcements
Newsletter
Pages
phpBB Arcade
Quickedit
Username BBCode
'' Posting Buttons ''
13 given 1
Re: Smilie Signs
I changed here the code to:
<select class="gensmall" name="addbbcode22" onchange="bbfontstyle('[sign=' + this.form.addbbcode22.options[this.form.addbbcode22.selectedIndex].value + '', '[/sign]');this.form.addbbcode22.selectedIndex = 0;" title="{L_BBCODE_SIGN_HELP}" style="height: 21px;">
Purge cache :wink:
Re: Smilie Signs
Also the search button is changing color when I enable this
Enabled:
Disabled:
Re: Smilie Signs
dmzx wrote:I changed here the code to:
Purge cache :wink:
I did.. you can test yourself if you want:
Login: Testaccount
Pasw: Testaccount
English support - ~ Arcadeplaats ~
Re: Smilie Signs
Solidjeuh wrote:Also the search button is changing color when I enable this.
There is a search smilie that uses the search class in the selection icons. I will have to change that.
Let me look into this. It's weird that name="smiliesign" wouldn't side step a conflict and work.
EDIT:
@ Solidjeuh, looking at your source codes on your site you have two smiliesigns selections.
Source codes in posting 0n line 201 begins one of them and on line 407 begins the other one.
// Line 201 after username bbcodes.
	<select class="gensmall" name="smiliesign" onchange="bbfontstyle('[sign=' + this.form.smiliesign.options[this.form.smiliesign.selectedIndex].value + '', '[/sign]');this.form.smiliesign.selectedIndex = 0;" title="Smilie sign: [sign=name]text[/sign]" style="height: 21px;">
// Line 407 after username bbcodes.
Yes you have two username bbcodes going on also. Check your files in your extensions.
The smiliesigns has only three files in the template/event/ directory...
dmzx_mchat_buttons_after.html - overall_header_head_append.html - posting_editor_buttons_custom_tags_before.html
You have some code duplicated somewhere listing those two extensions twice.
1 given 1
Re: Smilie Signs
Not looked but sounds like 2 or more events with the same name ?
Re: Smilie Signs
Yes just added to my post above. username and smiliesigns are duplicated on his site.
1 given 1
Re: Smilie Signs
Extension Download: Searching conflicts... stay tuned. Image i wanted to install it and test this version do i really have to go steal it :rolling:
Re: Smilie Signs
1 given 1
Re: Smilie Signs
Yup confirm no input within the forum :rolling:
works perfect on fresh install
