3.1.x Extensions Database 3.1 / 3.2Total edited posts
Total edited posts
Extension Name: Total edited posts
This extension shows total edited posts on index.
[travis]dmzx/Total-edited-posts[/travis]
  2. Unzip the downloaded release, and change the name of the folder to `totaleditedposts`.
  4. Copy the `totaleditedposts` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/totaleditedposts/composer.json
  6. Look for `Total edited posts` under the Disabled Extensions list, and click its `Enable` link.
