3.1 & 3.2 Extensions DatabaseTotal Attachments Filesize
Extension Name: Total Attachments Filesize
Special Thanks to: martin
This extension shows total attachments filezise on index.
downloadsystemcat?id=37
  2. Unzip the downloaded release, and change the name of the folder to `totalattfilesize`.
  4. Copy the `totalattfilesize` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/totalattfilesize/composer.json
  6. Look for `Total Attachments Filesize` under the Disabled Extensions list, and click its `Enable` link.
This topic has 5 replies
