Extensions Database 3.2 / 3.3 ⇒ 3.2 & 3.3 Browser & OS in Viewtopic
Armis
Re: Browser & OS in Viewtopic
A big thank you to you
The speed and reliability of your website in WANTETE WEB HOSTING
Your website and forum at 0.90 € /month without advertising or conditions.
Maclobster
Hello martin , can you help me to get it like in your SS?
B&O under the contact or Bottom of the mini profile?
Best regards
“A man searching for the Lost Paradise, can seem a fool to those who never sought the other world.”
-JM
-JM
You need to open the ext go to the styles folder open template/event folder and rename the event to viewtopic_body_contact_fields_after.html that will move it to under the contacts.
You will also get a error page so may need to open acp first or ftp to purge the cache.
Maclobster
Thank you for fast reply
i got now 2 times showing
You did it wrong read my other post again you need to rename the event file.
use these files.
use these files.
Maclobster
If i diod understand correctly i had it like you said, otherwise i need glasses
edit will do the download you replied
Maclobster
Thanks its working
But the idea was to get BO and contact on the bottom
Contact is at the bottom by default so your style or ext for them other images is an addon.
Maclobster
Thanks for the tips, done it now with all addons
networker007
I love this ext, but with SEO URL Rewriting doesn't work. the icons are not saved for later viewing.
is there a way to solve that?
thx in advanced
thx in advanced
Can you post a screenshot of this?networker007 wrote: 02 Jan 2021, 21:13 I love this ext, but with SEO URL Rewriting doesn't work. the icons are not saved for later viewing.
thx in advanced
networker007
After I wrote a post it looks like this in the safari - everything is good:
after returning to the post or reload, it looks like this in safai:
in firefox then like this:
I use the extension seourls (see here: https://github.com/tas2580/seourls)
my .htaccess looks like this:
my test-phpbb is under a subdir of the root
RewriteBase /phpbbtest
RewriteRule ^(.*)-f([0-9]*)/mcp.php(.*) mcp.php?%{QUERY_STRING} [L,R=301]
RewriteRule ^(.*)-f([0-9]*)/(.*)-t([0-9]*)-s([0-9]*).html viewtopic.php?f=$2&t=$4&start=$5&%{QUERY_STRING} [L]
RewriteRule ^(.*)-f([0-9]*)/(.*)-t([0-9]*).html viewtopic.php?f=$2&t=$4&%{QUERY_STRING} [L]
RewriteRule ^(.*)-f([0-9]*)/index-s([0-9]*).html viewforum.php?f=$2&start=$3&%{QUERY_STRING} [L]
RewriteRule ^(.*)-f([0-9]*)/ viewforum.php?f=$2&%{QUERY_STRING} [L]
RewriteRule ^(.*)-f([0-9]*) viewforum.php?f=$2&%{QUERY_STRING} [L]
