3.1 & 3.2 & 3.3 Extensions Database 3.1 / 3.2Special title
Fabliv
Re: Special title
Post by Fabliv »
French translation is my two cents. Thx for this Mod. :wink:
eunaumtenhoid
Re: Special title
Post by eunaumtenhoid »
* Brazilian Portuguese translation by eunaumtenhoid (c) 2018 [ver 1.0.1]
https://github.com/phpBBTraducoes/specialtitle
Re: Special title
Is there any updated about this ext? :eyes2: :question:
Re: Special title
ivailo95 wrote: 02 Feb 2018, 12:12 is there any updated about this ext? :eyes2: :question:
No why does it not work?
Re: Special title
dmzx wrote: 02 Feb 2018, 12:36
well..i suspect some mystake i mean
i add special title to user and suspect that is nos added
My PHPBB version is 3.2.1
Re: Special title
It works you may have to purge your browsers cache.
Re: Special title
martin wrote: 02 Feb 2018, 16:55 It works you may have to purge your browsers cache.
i did it ..but can't work..
Re: Special title
i purged the cache
Re: Special title
ivailo95 wrote: 05 Feb 2018, 18:55
It's a bit hard to fix some thing that dont work you need to give some info
phpbb version ?
styles being used ?
have you edited and files ?
Any ext's installed that make stle changes ?
if i posted my wifes toys dont work could you tell me the problem ?
Re: Special title
PHPBB version: 3.2.1
Style: Digi red
have you edited and files - no
Any ext's installed that make stle changes - no
Re: Special title
Anyone? :eyes2: :whistl:
Jester
Re: Special title
Post by Jester »
After you enable the special title , purge cache , delete cookies cache in your browser , goto user control panel and add the title , might have to be admin or moderator to have a special title.
can change some code to add reg users, ( admins / moderators / jr. admin only ones need it :eusa_dance: )
Re: Special title
You can set groups perms on who can use it.
Re: Special title
martin wrote: 09 Feb 2018, 12:08 You can set groups perms on who can use it.
im already setted it
my forum
https://rocknmetalbulgaria.eu/index.php
Test user: TestAccount
Test user password: 123456
pm me in the forum or write in the chat
and i will give u permission to test it
Re: Special title
dudes :eyes2: :roll: :question:
