3.2 & 3.3 Extensions Database 3.2 / 3.3Paypal Donation
Re: Paypal Donation
gpinpin wrote: 27 May 2016, 18:12 Hello
Concern with version 1.02
I went from 1.00 to 1.02 and problem ...
So I installed version 1.01 which appears to function properly
A + Gpinpin
bonjour
Souci avec la version 1.02
Je suis passé de la 1.00 à la 1.02 et problème...
Du coup j'ai installé la version 1.01 qui parait fonctionner correctement
A+ Gpinpin
What is the error?
gpinpin
Re: Paypal Donation
Post by gpinpin »
I put the 1.02 and I tell you tomorrow if I can
(I tested locally)
A+
Re: Paypal Donation
gpinpin wrote: 29 May 2016, 21:14 I put the 1.02 and I tell you tomorrow if I can
(I tested locally)
A+
Ok let me know :thumbup:
gpinpin
Re: Paypal Donation
Post by gpinpin »
After returning the 1.02 I extension in the image below that should be donation and if I click I have this because of errors
A +
Bonjour
Après avoir remis la 1.02 j'ai dans extension l'image ci dessous qui devrait etre donation et si je clic j'ai cette suite d'erreurs
A+
et
Erreur générale
Impossible de trouver le module « ./../includes/acp/\dmzx\donation\acp\donation_module.php »
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 571
CALL: trigger_error()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
karbiko
Re: Paypal Donation
Post by karbiko »
Hi, everyone!!
Here is my Spanish Translation for 1.0.2 version
Everything is working fine for me...
If you have any suggest or something is wrong, contact me by email
See you!! :wave:
Re: Paypal Donation
gpinpin wrote: 30 May 2016, 09:14 Hello
A +
Bonjour
A+
et
Erreur générale
BACKTRACE
CALL: msg_handler()
LINE: 571
LINE: 81
Try to delete the ACP module also and install the extension again.
Re: Paypal Donation
karbiko wrote: 30 May 2016, 20:11 Hi, everyone!!
gpinpin
Re: Paypal Donation
Post by gpinpin »
Que veux tu dire par
***Essayez de supprimer le module ACP aussi et installer l'extension à nouveau.***
Faut il le supprimer complètement ?
Pour l'instant
je le désactive
et je remplace le module d'extension 1.01 par le 1.02
puis je réactive le module*
*module = l'extension
What do you mean by
*** Try to delete the ACP module also and install the extension again. ***
He must completely remove it?
For the moment
I disable
and I replace the expansion module 1.01 by 1.02
I then reactivates the module *
* Module = extension
A+ Gpinpin
nextgen
Re: Paypal Donation
Post by nextgen »
Hi dmzx, the donation extension work with phpBB 3.2.x? :smile:
Re: Paypal Donation
nextgen wrote: 29 Jun 2016, 04:51 Hi dmzx, the donation extension work with phpBB 3.2.x? :smile:
Yes it will work.
gpinpin
Re: Paypal Donation
Post by gpinpin »
Bonjour
Je reviens après quelques essais
Je suis bien en version 1.02 et il fallait bien la supprimer complètement la 1.01 avant d'installer la 1.02
Merci à vous
Gpinpin
I come back after a few tries
I am to version 1.02 and it was necessary to remove the 1.01 prior to installing the 1.02
thank you
Gpinpin
Avez vous language French pour cette extension?
Have you French language for this extension?
Re: Paypal Donation
Yes disable and delete data in ACP and then reinstall new version.
There is no French language yet.
Antaka
Re: Paypal Donation
Post by Antaka »
dmzx wrote: 07 Aug 2016, 14:13
Hi dmzx
I undertake to make the French translation for the extension "Paypal donation v1.0.2"
I'm working on since yesterday also, I offer you some French translation on your github account
best regard
Re: Paypal Donation
Antaka
Re: Paypal Donation
Post by Antaka »
Hi dmzx
Here is my French Translation for the extension "Paypal Donation v1.0.2"
Otherwise your github account for the extension Paypal donation, we would say that you have not updated, we always see this version 1.0.1
Best regards
Paypal Donation v1.0.2 @dmzx - Translate French by Takashi.zip
