3.1 & 3.2 Extensions Database 3.1 / 3.2 ⇒ Screen resolution in viewtopic
NAPWR Online
- Donator
Re: Screen resolution in viewtopic
Works fine on PHPBB3.2.3
purged users, purged cache, and logged out and back in.
My name is Dave I, and all things are out there, and we are in here
Version 3.3.8
phpBB encountered an error building the container due to an installed extension. For this reason, all extensions have been temporarily disabled. Please try purging your forum cache. All extensions will automatically be re-enabled once the container error is resolved. If this error continues, please visit phpBB.com for support.
Exception: The file "/home/bgrockeu/public_html/ext/dmzx/screenresolution/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @request").
#0 /home/bgrockeu/public_html/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/bgrockeu/...')
#1 /home/bgrockeu/public_html/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/bgrockeu/public_html/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/bgrockeu/public_html/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/bgrockeu/public_html/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/bgrockeu/public_html/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/bgrockeu/public_html/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/bgrockeu/public_html/phpbb/di/container_builder.php(223): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/bgrockeu/public_html/common.php(117): phpbb\di\container_builder->get_container()
#9 /home/bgrockeu/public_html/adm/index.php(23): require('/home/bgrockeu/...')
#10 {main}You do not have the required permissions to view the files attached to this post! Maybe your post count is too low.
- Banned
Replace services.yml file by this:
services:
dmzx.screenresolution.listener:
class: dmzx\screenresolution\event\listener
arguments:
- '@request'
- '@dbal.conn'
- '@user'
- '@template'
tags:
- { name: event.listener }-
Fredisland
(phpBB 3.3.10 - PHP 8.12)
Great extension, but doesn't work
. Resolution field is empty.
I modified services.yml to install the extension, I purged phpBB cache, I logged out, I purged browser cache, I logged in... And the filed is always empty. Do you know if it's just a problem with phpBB 3.3.10 ?
Thank you very much.
It works.
clight77 Online
- Donator
I am on 3.3.10 and it works fine, maybe you have another ext conflicting it.Fredisland wrote: 19 May 2023, 17:02 (phpBB 3.3.10 - PHP 8.12)
Great extension, but doesn't work. Resolution field is empty.
Sll post removed for being a dork
Board version: 3.3.10
Same observation, the value is empty in viewtopic. The user_resolution colume value is empty in database also.
You need to log out then back in so it can grab data.
That worked. And those instructions are on the first post in this topic. Now I feel like a ssl.
Just for info it DOES work on 3.3.10 just done a fresh install.
Yea they got it... "Just log out then back in so it can grab data."
I would even add, purge sessions in acp after this install so everyone else is logged out.
Then the grabbing can begin. What do you think?
Fredisland
Logged out. Sessions purged. Cache purged. All cookies destroyed.
... But no Screen Resolution on Firefox and Chrome, whether with an administrator account or as a simple user 😭,
And I have noticed than no new cookie is created and nothing in the database is created.
Am i cursed? Or maybe an extension is blocking this one?
Reedit : I've deleted it, no more time for that.
