3.2 & 3.3 Extensions Database 3.2 / 3.3Browser & OS in Viewtopic
zardos
Re: Browser & OS in Viewtopic
Post by zardos »
Thanks :tumbsyes:
killfrenzy
Post by killfrenzy »
dmzx wrote: 11 years ago Extension Name: Browser & OS in Viewtopic
This extension shows browser icon and OS icon in viewtopic.
Works with new made posts and older posts will be indicated like this Image untill you edit the post.
Added Windows 10 and Spartan browser
There's nothing show in PBWOW3 style under prosilver?
Older posts are indicated like this:
  2. Unzip the downloaded release, and change the name of the folder to `browsericon`.
  4. Copy the `browsericon` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/browsericon/composer.json
  6. Look for `Browser & OS in Viewtopic` under the Disabled Extensions list, and click its `Enable` link.
I tried two times but still doesn't appear in my forum. I'm using PBwow style
Visit my blog http://androidcribs.com Androidcribs.comAndroidcribs Image
Then maybe the event is not correct in your style.
Will contact you later to check some things.
killfrenzy
dmzx wrote: 10 years ago Then maybe the event is not correct in your style.
Thanks Sir. Did you fix already?
lopoto
Post by lopoto »
Thx. :beers:
sakkiotto
Post by sakkiotto »
Some fix for tapatalk posters? after 3.1.7 or 3.1.8 update this code not works (perhaps because tapatalk update?)
	// Detect Tapatalk
   if ($browser == 'Tapatalk')
      if ($browser_version != '')
         $ver = substr($browser_version, 0, 1);
         if ($ver >= 2)
            $browser .= ' '. $ver;
            $browser_version = '';
   else if (!empty($browser_version) && $browser_version == '3.5.7')
      if ($browser == 'Firefox')
         $browser = 'Tapatalk';
Peralta
Post by Peralta »
How to adjust to recognize M$ Edge?
User agent:
Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko)
 Chrome/46.0.2486.0 Safari/537.36 Edge/13.10586
Peralta wrote: 10 years ago How to adjust to recognize M$ Edge?
User agent:
This should be in like:
// Edge to Spartan
	if ($browser == 'Edge')
		$browser = 'Spartan';
Peralta
Post by Peralta »
Test with M$ Edge
EDIT: Yes, works. Ty dmzx :thumbup:
taledus
Post by taledus »
Hey dmzx, I think it would be great if you could somehow adapt this mod and turn it into a "Favorites" type mod. Users could select their favorite OS, Browser, Games system, and a grip of other favorite things, which would display similarly.
That would help with the issue of a moderator editing and their information displaying instead of the OP.
Null
Post by Null »
Will this extension have an update with all these adjustments?
taledus wrote: 10 years ago Hey dmzx, I think it would be great if you could somehow adapt this mod and turn it into a "Favorites" type mod. Users could select their favorite OS, Browser, Games system, and a grip of other favorite things, which would display similarly.
Need to check on that, but that will a other extension then.
Null wrote: 10 years ago Will this extension have an update with all these adjustments?
This one not.
ircfc
Post by ircfc »
Please update this plugin for old threads
At the same time that Windows-browser or by putting a new thread was specified to be applied to old threads
Bye
ZippeL
Post by ZippeL »
UPDATE `your_db`.`prefix_yourtable` SET `user_agent`='Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/52.0.2743.116 Safari/537.36' WHERE `user_agent` is NULL;
This's for all undefined user_agent in old posts.
[ Post made via Samsung Galaxy S4 ] Image
