Pls can you translate of germen ?
3.1 & 3.2 & 3.3 Extensions Database 3.1 / 3.2 ⇒ PM Notify & Guest Register bar
sile
Re: PM Notify & Guest Register bar
Thanks so much dmzx
RedArrow
Hello all.
I loved this Extension, so I've added it my board and modified it a bit. And though, well why not share!
So here is my edited version of the Extension;
Previews:
I've changed the CSS, body.html and image files, so you can have two separate images displayed either side of your message (as shown above), or in my case - flipped images.
Just copy and paste the following into the relevant files:
pmregbar.css:
overall_header_body_before.html:
Images i used are attached.
Hope my contribution helps some people
Previews:
pmregbar.css:
#info {
overflow: visible;
min-width: 750px;
width: 100%;
position: fixed;
left: 0;
z-index:200;
/*margin-top: -8px;*/
font-family: Verdana, Arial, Helvetica, sans-serif;
font-size: 1.5em;
font-weight: bold;
#infobar a, #infobar a:link, #infobar a:visited, #infobar a:active {
display: block;
float: left;
width:100%;
clear: both;
color: #fff;
padding: .85em 0 .85em 0;
border-bottom: .25em solid #fff;
text-align: center;
text-decoration: none;
background-image: url("./images/pmreg.png");
background-position: bottom;
background-repeat:repeat-x;
#infobar a:hover {
color: #fff;
background-position: top;
cursor: pointer;
.pm-mail-left-side {
background: url("images/mail_left.png");
background-repeat: no-repeat;
background-position: left;
padding: 20px 44px;
vertical-align:middle;
.pm-mail-right-side {
background: url("images/mail_right.png");
background-position: right;
padding: 20px 44px;
.pm-reg-left-side{
background: url("images/reg_left.png");
padding: 20px 46px;
.pm-reg-right-side{
background: url("images/reg_right.png");
padding: 20px 46px;
/* Responsive Layout
@media only screen and (max-width: 700px), only screen and (max-device-width: 700px) {
.pm-mail {
display: none;
.pm-reg{
display: none;
#info {
min-width: 300px;
<!-- IF not S_USER_LOGGED_IN and not S_IS_BOT and not S_IN_UCP and PMREGBAR_ENABLEREG -->
<div id="info">
<div id="infobar">
<a href="{U_REGISTER}"><span class="pm-reg-left-side"></span><!-- IF not PMREGBAR_ENABLE_TEXT -->{L_PMREGBAR_WELCOME}<!-- ELSE -->{PMREGBAR_TEXT_FIELD} <!-- ENDIF --><span class="pm-reg-right-side"></span></a>
</div>
</div>
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN and S_DISPLAY_PM and (S_USER_NEW_PRIVMSG or S_USER_UNREAD_PRIVMSG) and PMREGBAR_ENABLEPM -->
<div id="info">
<div id="infobar">
<a href="{U_PRIVATEMSGS}"><span class="pm-mail-left-side"></span>{L_PMREGBAR_PM}<span class="pm-mail-right-side"></span></a>
</div>
</div>
<!-- ENDIF -->Hope my contribution helps some people
- Donator
Great but image #2 overruns the search.
RedArrow
Yeah, I know it goes over the search field.
It's fine though, as they should be logged-in to search / receive PM's.
If anyone does choose to use my edit, they can also edit it.
Also a note - It's setup to use the "pbtech" Style.
- Donator
I do not use that ext, but I am sure that the overrun in ccs can be fixed.
I am sure those that use this will find it helpfull for sure.
- Donator
I may install on my test site to see if I can help out :)
Antaka
Hi the people
Translate French converted by me
Enjoy it !
Enjoy it !
Musiker15
German Translation
nelflucifer
Hi! Translations into Russian.
English Forums
Galixte de EzCom
Hi dmzx,
is there a version for phpBB 3.2.x ?
seacoast
Is it possible to reposition the register/pm bar? It sits right on top of my login link.
