Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 Referrals
3.1.x & 3.2.x
15 given 2
Re: Referrals
Yes try it :wink:
Matrixer
Re: Referrals
Post by Matrixer »
dmzx wrote: 22 Feb 2017, 22:42Yes try it :wink:
Ok, will do.. should I just update or delete everything and reinstall - what's the best practice?
15 given 2
Re: Referrals
Matrixer wrote: 22 Feb 2017, 22:47
Disable and upload new files then re-enable. (dont delete data if you dont want to lose any data)
Matrixer
Re: Referrals
Post by Matrixer »
dmzx wrote: 22 Feb 2017, 22:49
Ok, done - will report back when I have some results... at least next Beers are on me :beers: :beers: :beers:
wads24
0 given 2
Re: Referrals
Post by wads24 »
Where is the unique referral link that the user shares?
15 given 2
Re: Referrals
wads24 wrote: 19 Mar 2017, 19:41 Where is the unique referral link that the user shares?
Look in UCP settings under Referrals tab.
wads24
0 given 2
Re: Referrals
Post by wads24 »
Thanks! I didn't see that on your instructions. I like your extensions! Great job
bcurran3
Re: Referrals
Post by bcurran3 »
I can't get this to work.
I tried a few months ago. Installed. Looked at the link. Opened a different browser and used the link. Created a test account. Viewed my profile expecting to see a referral count of 1, it had 0. I deleted the account, repeated, same results.
I'm bored and can't sleep, decided to try again. This time I thought to myself, "Self, maybe there NEEDS to be a contest." So I created a contest for 12 months and set it to one post requirement. I opened a different browser and used the link. Created a test account. Viewed my profile expecting to see a referral count of 0, it was zero. I validated the test user, I logged in as the test user, I posted as the test user. I posted a 2nd message as the test user. I looked an my profile expecting to see a referral account of 1, it was 0 again.
What gives?
My best guess: possibly not compatible with tecktron/membersonly which makes the landing page sitename.com/ucp.php?mode=login? Or maybe doesn't work with 3.2?
soi6269
Re: Referrals
Post by soi6269 »
How do i connect it with ultimate point system :eyes2:
farnhamit
Re: Referrals
Post by farnhamit »
DMZX I am trying to install the Referral Mod on 3.2phpbb why is it not showing in the mod section on my ACP?
Re: Referrals
farnhamit wrote: 17 Aug 2017, 11:42 DMZX I am trying to install the Referral Mod on 3.2phpbb why is it not showing in the mod section on my ACP?
Did you upload the files correct? /ext/dmzx/referral/
And enabled the extension in ACP / CUSTOMIZE ?
And it's in the Extension tab in ACP, phpBB 3.1 & 3.2 don't use MODS anymore.
farnhamit
Re: Referrals
Post by farnhamit »
Solidjeuh wrote: 17 Aug 2017, 14:25
Thank you Solidjeuh, Your comment made me rethink my steps and i put referrals rather than referral. All fixed! :) Thank you
seacoast
Re: Referrals
Post by seacoast »
I use .htaccess to redirect to https on my site. Will the referral link still work with that?
Thanks!
1 given 2
Re: Referrals
Sure will if by any chance some one landed up at http your htaccess kicks in.
seacoast
Re: Referrals
Post by seacoast »
Installed and it worked like a charm. :)
