Extensions Database 3.1 / 3.2 ⇒ 3.1.x [RC] Tables bbCode
3.1.x & 3.2.x
Anuj Dhawan
Re: Tables bbCodes
Post by Anuj Dhawan »
Great and good luck Sniper_E. :thumbup:
Puchahawa
Re: Tables bbCodes
Post by Puchahawa »
That looks promising though I'm getting some interesting results. :wtf:
I followed your example 2 of a head row and 1 data row and got this using aero black and 3.1.9. Not sure if I messed up somewhere or what. it has the head under the data row and no bg. Like I said it could be me messing up, it's late. :lol:
This is the result in prosilver
Re: Tables bbCodes
Anuj Dhawan wrote: 13 Sep 2016, 03:51Great and good luck Sniper_E. :thumbup:
Thank you Anuj! That good luck did the trick. I have the table selections working in the block choices like tamarin asked for.
Right now I have the tables selections setup from 1 column 1 row to 5 columns 5 rows
When I asked about what you guys would prefer I only got 1 answer.
tamarin wrote: 15 Jan 2016, 07:03I think 10 rows and 5 columns will suffice.
Thank you in advance.
Shall I go ahead and make it 10 rows? I guess it wouldn't hurt to have more choices.
@ Puchahawa... Do you have all the bbCodes in ACP? Or did you Clear the Cache in ACP? prosilver should have shown correctly.
In the images you posted I saw a [th=45] in there. Your 4 column widths equals 110% That should be [th=35]
[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][td]Text2[/td][td]Text3[/td][td]Text4[/td][/tr][/tbody][/table]
Did I have that typo in the language file? It looks fine in my copy, which I thought I zipped up. Just look and see what you have off.
EDIT: Ah I see now. Your [td=15] is wrong. All of them. The [td]s do not have a width in this update.
Anuj Dhawan
Re: Tables bbCodes
Excellent! Yes, having more choices would not hurt! :)
Re: Tables bbCodes
OK here is another update with tamarin's table selection box.
tables_test2.zip
I'm so glad tamarin brought that option up... It makes for a much better drop down. I like it. I like it alot!
Now I'll expand the table selections to 5 Columns and 10 Rows. Then see what else it needs.
Halla if you see anything that needs to be changed or added. Thanks for testing this guys. We're getting there...
Anuj Dhawan
Re: Tables bbCodes
Looks nice and works well.
Fast_Eddie
Re: Tables bbCodes
Post by Fast_Eddie »
SWEET !!!! love it Ed !!!! _________AND_____________I see you fixed the color selection box!!!!! :thumbup: :thumbup:
Very nice work! Thank you :buigen:
:beers: Retirement 2024!
Puchahawa
Re: Tables bbCodes
Post by Puchahawa »
Making progress. :eusa_dance: I made the correction you shared and it's right side up. :lol: The layout is still a bit weird though. Disabled - deleted data - removed the bbcodes in case - purged cache, and re-activated
this is with prosilver
here's Aeroblack
This is the code I used for the two pics. All the bbcodes are showing.
[table=70][thead][tr=bg1][th=15]title 1[/th][th=35]title 2[/th][th=15]Title3[/th][th=35]title4[/th][/tr][/thead]
[tbody][tr=none][td]text 1[/td][td]text 2[/td][td]text 3[/td][td]text4[/td][/tr]
[tr=none][td]text 1[/td][td]text 2[/td][td]text 3[/td][td]text4[/td][/tr][/tbody][/table]
Figure I'll check out the selection box when this is figured out. Probably more operator error. :wtf:
Re: Tables bbCodes
Yea your codes in the textare should look like this...
[table=70][thead][tr=null][th=15]title 1[/th][th=35]title 2[/th][th=15]Title3[/th][th=35]title4[/th][/tr][/thead][tbody][tr=bg2][td]text 1[/td][td]text 2[/td][td]text 3[/td][td]text4[/td][/tr][tr=bg1][td]text 1[/td][td]text 2[/td][td]text 3[/td][td]text4[/td][/tr][tr=bg2][td]text 1[/td][td]text 2[/td][td]text 3[/td][td]text4[/td][/tr][/tbody][/table]
All one line. From what I see in your image it's not pulling the codes I have setup in the language file.
The [tr]s before the [th]s should use null [tr=null]
The [tr]s before the [td]s should use bg1 or bg2 [tr=bg1] or [tr=bg2]
Everything else you have looks fine.
Puchahawa
Re: Tables bbCodes
Post by Puchahawa »
Now were cooking. :rolling: Operator error was in effect. :whistl: Thanks for the insight. :tumbsyes: Added your info to the help lines. :smile:
Aeroblack.
Re: Tables bbCodes
Far out! Now you have to start over again. :rolling:
First post updated to Version 2.0.0
Puchahawa
Re: Tables bbCodes
Post by Puchahawa »
I'm ready. :lol: Quick question with v2.0.0 do we need to disable AND delete data or just disable?
Re: Tables bbCodes
You already updated with the test ones I posted... You could probably just copy the files over, over writing the ones you have.
Then refresh your browser. Maybe clear server cache also.
Puchahawa
Re: Tables bbCodes
Post by Puchahawa »
Ok, updated to v2. Now my question is, where would the tables selection dropdown show up? running 3.1.9 if that matters. Don't see anything obvious and still show the normal table, tr, td etc...
Answered my own question. :mml: I'm running abbc3 v3.1.3 and I remembered that you had to make an adjustment for the smilie signs extension for people that used that ext. So I copied the vse_abbc3_posting_editor_buttons_custom_tags_before.html file from the signs ext and edited it by replacing the signs info with this <!-- INCLUDE tables_posting_editor_buttons.html --> VERY NICE option Sniper.
:buigen: :buigen: :buigen: :thankyou:
For those that are using the abbc3 extension you will want to go in and remove the check from the "display on posting page" box for each of the table bbcodes as the individual bbcode buttons aren't needed.
Re: Tables bbCodes
Puchahawa wrote: 13 Sep 2016, 22:02I copied the vse_abbc3_posting_editor_buttons_custom_tags_before.html file from the signs ext and edited it.
VERY NICE option Sniper. :buigen: :buigen: :buigen: :thankyou:
Awesome,ImageI didn't even think about that. :thankyou:
I'm sure there are more to add for other extensions but I added that one to it for now. :thumbup:
I noticed that it could be confusing when after the table code is inserted into the textarea, editing it with your text.
There were a lot of rows with Tex1 and Text2 going down in the table. I added a row number to make it more user friendly.
Example:
Now it reads Text34 showing it's in the 3rd column over and in the 4th row down.
And it reads Text59 showing it's in the 5th column over and in the 9th row down.
This will make it much easier to locate exactly which text you want to edit.
Two files have changed since the last two of you downloaded it.
(New download has been updated on the first post with these changes.)
The language/en/tables.php
<?php
* Tables bbCode Extension
* @author (c) 2015 Sniper_E - http://www.sniper-e.com
* @license		GNU General Public License, version 2 (GPL-2.0)
 * DO NOT CHANGE
if (!defined('IN_PHPBB'))
	exit;
if (empty($lang) || !is_array($lang))
	$lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Advanced MODx Instructions en language file.
// @author (c) 2015 Sniper_E <http://www.sniper-e.com>
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
// Some characters you may want to copy&paste:
$lang = array_merge(
	$lang, array(
// Table bbCode Help and Button Title
		'TABLES_BBCODE_HELP'	=> 'Select a Table',
		'TABLES_TITLE'			=> 'Tables',
		'TABLES_ALERT'			=> 'Please click on one of the table selections.',
// Table Selection Titles on Hover
		'TABLE11_TITLE'			=> 'Table - 1 column 1 row',
		'TABLE12_TITLE'			=> 'Table - 1 column 2 rows',
		'TABLE13_TITLE'			=> 'Table - 1 column 3 rows',
		'TABLE14_TITLE'			=> 'Table - 1 column 4 rows',
		'TABLE15_TITLE'			=> 'Table - 1 column 5 rows',
		'TABLE16_TITLE'			=> 'Table - 1 column 6 rows',
		'TABLE17_TITLE'			=> 'Table - 1 column 7 rows',
		'TABLE18_TITLE'			=> 'Table - 1 column 8 rows',
		'TABLE19_TITLE'			=> 'Table - 1 column 9 rows',
		'TABLE10_TITLE'			=> 'Table - 1 column 10 rows',
		'TABLE21_TITLE'			=> 'Table - 2 columns 1 row',
		'TABLE22_TITLE'			=> 'Table - 2 columns 2 rows',
		'TABLE23_TITLE'			=> 'Table - 2 columns 3 rows',
		'TABLE24_TITLE'			=> 'Table - 2 columns 4 rows',
		'TABLE25_TITLE'			=> 'Table - 2 columns 5 rows',
		'TABLE26_TITLE'			=> 'Table - 2 columns 6 rows',
		'TABLE27_TITLE'			=> 'Table - 2 columns 7 rows',
		'TABLE28_TITLE'			=> 'Table - 2 columns 8 rows',
		'TABLE29_TITLE'			=> 'Table - 2 columns 9 rows',
		'TABLE20_TITLE'			=> 'Table - 2 columns 10 rows',
		'TABLE31_TITLE'			=> 'Table - 3 columns 1 row',
		'TABLE32_TITLE'			=> 'Table - 3 columns 2 rows',
		'TABLE33_TITLE'			=> 'Table - 3 columns 3 rows',
		'TABLE34_TITLE'			=> 'Table - 3 columns 4 rows',
		'TABLE35_TITLE'			=> 'Table - 3 columns 5 rows',
		'TABLE36_TITLE'			=> 'Table - 3 columns 6 rows',
		'TABLE37_TITLE'			=> 'Table - 3 columns 7 rows',
		'TABLE38_TITLE'			=> 'Table - 3 columns 8 rows',
		'TABLE39_TITLE'			=> 'Table - 3 columns 9 rows',
		'TABLE30_TITLE'			=> 'Table - 3 columns 10 rows',
		'TABLE41_TITLE'			=> 'Table - 4 columns 1 row',
		'TABLE42_TITLE'			=> 'Table - 4 columns 2 rows',
		'TABLE43_TITLE'			=> 'Table - 4 columns 3 rows',
		'TABLE44_TITLE'			=> 'Table - 4 columns 4 rows',
		'TABLE45_TITLE'			=> 'Table - 4 columns 5 rows',
		'TABLE46_TITLE'			=> 'Table - 4 columns 6 rows',
		'TABLE47_TITLE'			=> 'Table - 4 columns 7 rows',
		'TABLE48_TITLE'			=> 'Table - 4 columns 8 rows',
		'TABLE49_TITLE'			=> 'Table - 4 columns 9 rows',
		'TABLE40_TITLE'			=> 'Table - 4 columns 10 rows',
		'TABLE51_TITLE'			=> 'Table - 5 columns 1 row',
		'TABLE52_TITLE'			=> 'Table - 5 columns 2 rows',
		'TABLE53_TITLE'			=> 'Table - 5 columns 3 rows',
		'TABLE54_TITLE'			=> 'Table - 5 columns 4 rows',
		'TABLE55_TITLE'			=> 'Table - 5 columns 5 rows',
		'TABLE56_TITLE'			=> 'Table - 5 columns 6 rows',
		'TABLE57_TITLE'			=> 'Table - 5 columns 7 rows',
		'TABLE58_TITLE'			=> 'Table - 5 columns 8 rows',
		'TABLE59_TITLE'			=> 'Table - 5 columns 9 rows',
		'TABLE50_TITLE'			=> 'Table - 5 columns 10 rows',
// Tables by Columns and Rows
		'TABLE11'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text[/td][/tr][/tbody][/table]',
		'TABLE12'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][/tbody][/table]',
		'TABLE13'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][/tbody][/table]',
		'TABLE14'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][tr=bg1][td]Text4[/td][/tr][/tbody][/table]',
		'TABLE15'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][tr=bg1][td]Text4[/td][/tr][tr=bg2][td]Text5[/td][/tr][/tbody][/table]',
		'TABLE16'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][tr=bg1][td]Text4[/td][/tr][tr=bg2][td]Text5[/td][/tr][tr=bg1][td]Text6[/td][/tr][/tbody][/table]',
		'TABLE17'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][tr=bg1][td]Text4[/td][/tr][tr=bg2][td]Text5[/td][/tr][tr=bg1][td]Text6[/td][/tr][tr=bg2][td]Text7[/td][/tr][/tbody][/table]',
		'TABLE18'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][tr=bg1][td]Text4[/td][/tr][tr=bg2][td]Text5[/td][/tr][tr=bg1][td]Text6[/td][/tr][tr=bg2][td]Text7[/td][/tr][tr=bg1][td]Text8[/td][/tr][/tbody][/table]',
		'TABLE19'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][tr=bg1][td]Text4[/td][/tr][tr=bg2][td]Text5[/td][/tr][tr=bg1][td]Text6[/td][/tr][tr=bg2][td]Text7[/td][/tr][tr=bg1][td]Text8[/td][/tr][tr=bg2][td]Text9[/td][/tr][/tbody][/table]',
		'TABLE10'	=> '[table=30][thead][tr=null][th=100]Title[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][/tr][tr=bg1][td]Text2[/td][/tr][tr=bg2][td]Text3[/td][/tr][tr=bg1][td]Text4[/td][/tr][tr=bg2][td]Text5[/td][/tr][tr=bg1][td]Text6[/td][/tr][tr=bg2][td]Text7[/td][/tr][tr=bg1][td]Text8[/td][/tr][tr=bg2][td]Text9[/td][/tr][tr=bg1][td]Text10[/td][/tr][/tbody][/table]',
		'TABLE21'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][td]Text2[/td][/tr][/tbody][/table]',
		'TABLE22'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][/tbody][/table]',
		'TABLE23'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][/tbody][/table]',
		'TABLE24'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][/tr][/tbody][/table]',
		'TABLE25'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][/tr][/tbody][/table]',
		'TABLE26'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][/tr][/tbody][/table]',
		'TABLE27'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][/tr][/tbody][/table]',
		'TABLE28'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][/tr][/tbody][/table]',
		'TABLE29'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][/tr][/tbody][/table]',
		'TABLE20'	=> '[table=45][thead][tr=null][th=30]Title1[/th][th=70]Title2[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][/tr][tr=bg1][td]Text110[/td][td]Text210[/td][/tr][/tbody][/table]',
		'TABLE31'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][td]Text2[/td][td]Text3[/td][/tr][/tbody][/table]',
		'TABLE32'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][/tbody][/table]',
		'TABLE33'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][/tbody][/table]',
		'TABLE34'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][/tr][/tbody][/table]',
		'TABLE35'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][/tr][/tbody][/table]',
		'TABLE36'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][/tr][/tbody][/table]',
		'TABLE37'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][/tr][/tbody][/table]',
		'TABLE38'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][/tr][/tbody][/table]',
		'TABLE39'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][td]Text39[/td][/tr][/tbody][/table]',
		'TABLE30'	=> '[table=60][thead][tr=null][th=25]Title1[/th][th=50]Title2[/th][th=25]Title3[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][td]Text39[/td][/tr][tr=bg1][td]Text110[/td][td]Text210[/td][td]Text310[/td][/tr][/tbody][/table]',
		'TABLE41'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][td]Text2[/td][td]Text3[/td][td]Text4[/td][/tr][/tbody][/table]',
		'TABLE42'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][/tbody][/table]',
		'TABLE43'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][/tbody][/table]',
		'TABLE44'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][/tr][/tbody][/table]',
		'TABLE45'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][/tr][/tbody][/table]',
		'TABLE46'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][/tr][/tbody][/table]',
		'TABLE47'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][/tr][/tbody][/table]',
		'TABLE48'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][td]Text48[/td][/tr][/tbody][/table]',
		'TABLE49'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][td]Text48[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][td]Text39[/td][td]Text49[/td][/tr][/tbody][/table]',
		'TABLE40'	=> '[table=75][thead][tr=null][th=15]Title1[/th][th=35]Title2[/th][th=15]Title3[/th][th=35]Title4[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][td]Text48[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][td]Text39[/td][td]Text49[/td][/tr][tr=bg1][td]Text110[/td][td]Text210[/td][td]Text310[/td][td]Text410[/td][/tr][/tbody][/table]',
		'TABLE51'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text1[/td][td]Text2[/td][td]Text3[/td][td]Text4[/td][td]Text5[/td][/tr][/tbody][/table]',
		'TABLE52'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][/tbody][/table]',
		'TABLE53'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][/tbody][/table]',
		'TABLE54'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][td]Text54[/td][/tr][/tbody][/table]',
		'TABLE55'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][td]Text54[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][td]Text55[/td][/tr][/tbody][/table]',
		'TABLE56'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][td]Text54[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][td]Text55[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][td]Text56[/td][/tr][/tbody][/table]',
		'TABLE57'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][td]Text54[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][td]Text55[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][td]Text56[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][td]Text57[/td][/tr][/tbody][/table]',
		'TABLE58'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][td]Text54[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][td]Text55[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][td]Text56[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][td]Text57[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][td]Text48[/td][td]Text58[/td][/tr][/tbody][/table]',
		'TABLE59'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][td]Text54[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][td]Text55[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][td]Text56[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][td]Text57[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][td]Text48[/td][td]Text58[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][td]Text39[/td][td]Text49[/td][td]Text59[/td][/tr][/tbody][/table]',
		'TABLE50'	=> '[table=90][thead][tr=null][th=20]Title1[/th][th=20]Title2[/th][th=20]Title3[/th][th=20]Title4[/th][th=20]Title5[/th][/tr][/thead][tbody][tr=bg2][td]Text11[/td][td]Text21[/td][td]Text31[/td][td]Text41[/td][td]Text51[/td][/tr][tr=bg1][td]Text12[/td][td]Text22[/td][td]Text32[/td][td]Text42[/td][td]Text52[/td][/tr][tr=bg2][td]Text13[/td][td]Text23[/td][td]Text33[/td][td]Text43[/td][td]Text53[/td][/tr][tr=bg1][td]Text14[/td][td]Text24[/td][td]Text34[/td][td]Text44[/td][td]Text54[/td][/tr][tr=bg2][td]Text15[/td][td]Text25[/td][td]Text35[/td][td]Text45[/td][td]Text55[/td][/tr][tr=bg1][td]Text16[/td][td]Text26[/td][td]Text36[/td][td]Text46[/td][td]Text56[/td][/tr][tr=bg2][td]Text17[/td][td]Text27[/td][td]Text37[/td][td]Text47[/td][td]Text57[/td][/tr][tr=bg1][td]Text18[/td][td]Text28[/td][td]Text38[/td][td]Text48[/td][td]Text58[/td][/tr][tr=bg2][td]Text19[/td][td]Text29[/td][td]Text39[/td][td]Text49[/td][td]Text59[/td][/tr][tr=bg1][td]Text110[/td][td]Text210[/td][td]Text310[/td][td]Text410[/td][td]Text510[/td][/tr][/tbody][/table]',
And the styles/all/template/tables_posting_editor_buttons.html
		<span class="tables">
			<input type="button" class="button2" name="tables" id="tables" value="{L_TABLES_TITLE}" onclick="alert('{L_TABLES_ALERT}');" title="{L_TABLES_BBCODE_HELP}" />
			<span class="bg2 table-selections">
				<input type="submit" class="button2 table-button" name="table11" value="" onclick="insert_text('{L_TABLE11}'); return false;" title="{L_TABLE11_TITLE}" />
				<input type="submit" class="button2 table-button" name="table21" value="" onclick="insert_text('{L_TABLE21}'); return false;" title="{L_TABLE21_TITLE}" />
				<input type="submit" class="button2 table-button" name="table31" value="" onclick="insert_text('{L_TABLE31}'); return false;" title="{L_TABLE31_TITLE}" />
				<input type="submit" class="button2 table-button" name="table41" value="" onclick="insert_text('{L_TABLE41}'); return false;" title="{L_TABLE41_TITLE}" />
				<input type="submit" class="button2 table-button" name="table51" value="" onclick="insert_text('{L_TABLE51}'); return false;" title="{L_TABLE51_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table12" value="" onclick="insert_text('{L_TABLE12}'); return false;" title="{L_TABLE12_TITLE}" />
				<input type="submit" class="button2 table-button" name="table22" value="" onclick="insert_text('{L_TABLE22}'); return false;" title="{L_TABLE22_TITLE}" />
				<input type="submit" class="button2 table-button" name="table32" value="" onclick="insert_text('{L_TABLE32}'); return false;" title="{L_TABLE32_TITLE}" />
				<input type="submit" class="button2 table-button" name="table42" value="" onclick="insert_text('{L_TABLE42}'); return false;" title="{L_TABLE42_TITLE}" />
				<input type="submit" class="button2 table-button" name="table52" value="" onclick="insert_text('{L_TABLE52}'); return false;" title="{L_TABLE52_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table13" value="" onclick="insert_text('{L_TABLE13}'); return false;" title="{L_TABLE13_TITLE}" />
				<input type="submit" class="button2 table-button" name="table23" value="" onclick="insert_text('{L_TABLE23}'); return false;" title="{L_TABLE23_TITLE}" />
				<input type="submit" class="button2 table-button" name="table33" value="" onclick="insert_text('{L_TABLE33}'); return false;" title="{L_TABLE33_TITLE}" />
				<input type="submit" class="button2 table-button" name="table43" value="" onclick="insert_text('{L_TABLE43}'); return false;" title="{L_TABLE43_TITLE}" />
				<input type="submit" class="button2 table-button" name="table53" value="" onclick="insert_text('{L_TABLE53}'); return false;" title="{L_TABLE53_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table14" value="" onclick="insert_text('{L_TABLE14}'); return false;" title="{L_TABLE14_TITLE}" />
				<input type="submit" class="button2 table-button" name="table24" value="" onclick="insert_text('{L_TABLE24}'); return false;" title="{L_TABLE24_TITLE}" />
				<input type="submit" class="button2 table-button" name="table34" value="" onclick="insert_text('{L_TABLE34}'); return false;" title="{L_TABLE34_TITLE}" />
				<input type="submit" class="button2 table-button" name="table44" value="" onclick="insert_text('{L_TABLE44}'); return false;" title="{L_TABLE44_TITLE}" />
				<input type="submit" class="button2 table-button" name="table54" value="" onclick="insert_text('{L_TABLE54}'); return false;" title="{L_TABLE54_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table15" value="" onclick="insert_text('{L_TABLE15}'); return false;" title="{L_TABLE15_TITLE}" />
				<input type="submit" class="button2 table-button" name="table25" value="" onclick="insert_text('{L_TABLE25}'); return false;" title="{L_TABLE25_TITLE}" />
				<input type="submit" class="button2 table-button" name="table35" value="" onclick="insert_text('{L_TABLE35}'); return false;" title="{L_TABLE35_TITLE}" />
				<input type="submit" class="button2 table-button" name="table45" value="" onclick="insert_text('{L_TABLE45}'); return false;" title="{L_TABLE45_TITLE}" />
				<input type="submit" class="button2 table-button" name="table55" value="" onclick="insert_text('{L_TABLE55}'); return false;" title="{L_TABLE55_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table16" value="" onclick="insert_text('{L_TABLE16}'); return false;" title="{L_TABLE16_TITLE}" />
				<input type="submit" class="button2 table-button" name="table26" value="" onclick="insert_text('{L_TABLE26}'); return false;" title="{L_TABLE26_TITLE}" />
				<input type="submit" class="button2 table-button" name="table36" value="" onclick="insert_text('{L_TABLE36}'); return false;" title="{L_TABLE36_TITLE}" />
				<input type="submit" class="button2 table-button" name="table46" value="" onclick="insert_text('{L_TABLE46}'); return false;" title="{L_TABLE46_TITLE}" />
				<input type="submit" class="button2 table-button" name="table56" value="" onclick="insert_text('{L_TABLE56}'); return false;" title="{L_TABLE56_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table17" value="" onclick="insert_text('{L_TABLE17}'); return false;" title="{L_TABLE17_TITLE}" />
				<input type="submit" class="button2 table-button" name="table27" value="" onclick="insert_text('{L_TABLE27}'); return false;" title="{L_TABLE27_TITLE}" />
				<input type="submit" class="button2 table-button" name="table37" value="" onclick="insert_text('{L_TABLE37}'); return false;" title="{L_TABLE37_TITLE}" />
				<input type="submit" class="button2 table-button" name="table47" value="" onclick="insert_text('{L_TABLE47}'); return false;" title="{L_TABLE47_TITLE}" />
				<input type="submit" class="button2 table-button" name="table57" value="" onclick="insert_text('{L_TABLE57}'); return false;" title="{L_TABLE57_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table18" value="" onclick="insert_text('{L_TABLE18}'); return false;" title="{L_TABLE18_TITLE}" />
				<input type="submit" class="button2 table-button" name="table28" value="" onclick="insert_text('{L_TABLE28}'); return false;" title="{L_TABLE28_TITLE}" />
				<input type="submit" class="button2 table-button" name="table38" value="" onclick="insert_text('{L_TABLE38}'); return false;" title="{L_TABLE38_TITLE}" />
				<input type="submit" class="button2 table-button" name="table48" value="" onclick="insert_text('{L_TABLE48}'); return false;" title="{L_TABLE48_TITLE}" />
				<input type="submit" class="button2 table-button" name="table58" value="" onclick="insert_text('{L_TABLE58}'); return false;" title="{L_TABLE58_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table19" value="" onclick="insert_text('{L_TABLE19}'); return false;" title="{L_TABLE19_TITLE}" />
				<input type="submit" class="button2 table-button" name="table29" value="" onclick="insert_text('{L_TABLE29}'); return false;" title="{L_TABLE29_TITLE}" />
				<input type="submit" class="button2 table-button" name="table39" value="" onclick="insert_text('{L_TABLE39}'); return false;" title="{L_TABLE39_TITLE}" />
				<input type="submit" class="button2 table-button" name="table49" value="" onclick="insert_text('{L_TABLE49}'); return false;" title="{L_TABLE49_TITLE}" />
				<input type="submit" class="button2 table-button" name="table59" value="" onclick="insert_text('{L_TABLE59}'); return false;" title="{L_TABLE59_TITLE}" />
				<br />
				<input type="submit" class="button2 table-button" name="table10" value="" onclick="insert_text('{L_TABLE10}'); return false;" title="{L_TABLE10_TITLE}" />
				<input type="submit" class="button2 table-button" name="table20" value="" onclick="insert_text('{L_TABLE20}'); return false;" title="{L_TABLE20_TITLE}" />
				<input type="submit" class="button2 table-button" name="table30" value="" onclick="insert_text('{L_TABLE30}'); return false;" title="{L_TABLE30_TITLE}" />
				<input type="submit" class="button2 table-button" name="table40" value="" onclick="insert_text('{L_TABLE40}'); return false;" title="{L_TABLE40_TITLE}" />
				<input type="submit" class="button2 table-button" name="table50" value="" onclick="insert_text('{L_TABLE50}'); return false;" title="{L_TABLE50_TITLE}" />
			</span>
		</span>
