3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Member Profile Views
Painkiller88
Re: Member Profile Views
i am not familiar with the php syntax. How to change the event to not count user id 2 profile visits?
I am user ID 2 and i need to check profiles for spam, fake mail adresses but don't want to activate the counter event so i want to exclude my id
ORIGINAL:
if (($this->user->data['user_id'] != $user_id ) && ($this->user->data['user_id'] != ANONYMOUS) && (!$this->user->data['is_bot']))
Maybe add this?
&& ($this->user->data['user_id'] != 2) ???
thanks
ORIGINAL:
Maybe add this?
thanks
Yes you are on the correct way!Painkiller88 wrote: 03 Feb 2019, 13:08 Hi,
ORIGINAL:
Maybe add this?
thanks
Make it:
if (($this->user->data['user_id'] != $user_id ) && ($this->user->data['user_id'] != ANONYMOUS) && ($this->user->data['user_id'] != 2) && (!$this->user->data['is_bot']))-
awr
- Translators
Aforce
Excellent, thanks for the update. I find this to be quite a useful extension.
Exabot
Estonian translation.
Exabot
Repaired.
TrekRed
How to make sure that the view from the administrator is not displayed?
everymember in the forums can view every profileTrekRed wrote: 09 Apr 2020, 12:30 How to make sure that the view from the administrator is not displayed?
cvxcvx
Hi. Please updated.
Phpbb 3.3.9
Sam dissable all ext and stilo this error.
Phpbb 3.3.9
SQL ERROR [ mysqli ]
Expression #2 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'admin_forumtest.m.date' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055]
SQL
SELECT m.user_id, m.date, m.counter_user, u.username, u.user_colour, u.user_id, u.user_avatar, u.user_avatar_type, u.user_avatar_height, u.user_avatar_width FROM phpbb_memberprofileviews m, phpbb_users u WHERE m.view_id = 2 AND m.user_id = u.user_id GROUP BY m.user_id ORDER BY m.date DESC LIMIT 100
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 1023
CALL: trigger_error()
LINE: 202
FILE: [ROOT]/phpbb/db/driver/mysql_base.php
LINE: 45
LINE: 296
CALL: phpbb\db\driver\mysql_base->_sql_query_limit()
LINE: 337
CALL: phpbb\db\driver\driver->sql_query_limit()
FILE: [ROOT]/ext/dmzx/memberprofileviews/event/listener.php
LINE: 137
CALL: phpbb\db\driver\factory->sql_query_limit()
FILE: [ROOT]/vendor/symfony/event-dispatcher/EventDispatcher.php
LINE: 214
CALL: dmzx\memberprofileviews\event\listener->memberlist_view_profile()
LINE: 44
CALL: Symfony\Component\EventDispatcher\EventDispatcher->doDispatch()
FILE: [ROOT]/phpbb/event/dispatcher.php
LINE: 62
CALL: Symfony\Component\EventDispatcher\EventDispatcher->dispatch()
LINE: 46
CALL: phpbb\event\dispatcher->dispatch()
FILE: [ROOT]/memberlist.php
LINE: 757
CALL: phpbb\event\dispatcher->trigger_event() -
Bruce Banner
Having the same problem as the poster above. Can this be resolved, please?
