Author: [hidden]
Special thanks to: [hidden] & [hidden]
This extension shows the profile views count in profile.
[hidden] [hidden] [hidden]
[hidden]
- Short syntax.
- Add number format.
[hidden]
- Drop support for 3.1.
- Update tables.yml
- Twig update
[hidden]
Code update, validation version.
[hidden]
Added Avatars
Added count for users
Added ACP option to set value (Board features)
[hidden]
Added members who viewed profile
[hidden]
[hidden]
- Unzip the downloaded release, and change the name of the folder to `memberprofileviews`.
- Copy the `memberprofileviews` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/memberprofileviews/composer.json - Navigate in the ACP to `Customise -> Manage extensions`
- Look for `Member Profile Views` under the Disabled Extensions list, and click its `Enable` link.
