3.1.x Extensions Database 3.1 / 3.2 ⇒ [RC] Smilie Signs
Re: Smilie Signs
posting_editor_smilies_after.html
But the search function is messed up again..
~ Arcadeplaats ~ - search
Also background of search box changed again
Re: Smilie Signs
So where do you think I should put this?
We know it can not go inside the <div id="format-buttons"> </div> section with the other bbCodes.
I wish there was a way to make it play well with the others. Bad bbCode!
So it can go in...
posting_editor_subject_after or which is the same posting_editor_buttons_before
Or posting_editor_buttons_after or posting_editor_smilies_before or posting_editor_smilies_after
So it can go in...
Re: Smilie Signs
I think it's better to put it with the other smileys @ posting_editor_smilies_after
Re: Smilie Signs
I think I will put them everywhere.
Re: Smilie Signs
OK first post updated with new download. Please replace your copy and report any issues if you see any.
Re: Smilie Signs
Lazy boy ext add them all so it's not so far to move the mouseSniper_E wrote:I think I will put them everywhere.
Re: Smilie Signs
Perfect now! It all works. Also search function is good again!
Thank you!!
Thank you!!
vla20071
Re: Smilie Signs
I'm just in quick reply not working (generally no)
Re: Smilie Signs
That quick reply is in the viewtopic page so I'm sure it want work there.
But there is an extension that adds bbCodes to quick reply. If that was installed it should work there.
Otherwise we would have to expand the codes in this for it to work there.
vla20071
Re: Smilie Signs
Installed the extension QuickReply Reloaded
Re: Smilie Signs
I'm soo sorryyyyyyyyyy
But the yes smiley is conflicting with my dutch language
Instead of 'Ja' , my buttons now show 'Yes'
'YES' => 'yes',-
Re: Smilie Signs
No don't be sorry. Thank you for pointing that out. You have been a huge help.
I looked in the forum_root/language/en/common.php file and 'YES' was in there.
I had 'SEARCH', 'RULES' and 'YES' conflicting with the phpBB language files. I needed to know I had to fix that.
Let me go over the other phpBB language entries and classes to see if there is some others. I will update in a minute.
Re: Smilie Signs
OK I checked all the names and classes... I think that is the last name that will conflict with phpBB.
First post download updated.
Thank you for testing this extension out!
Re: Smilie Signs
Again not working, when I click the smiley is not sending to the textbox
Also language problem
