3.2 & 3.3 Extensions Database 3.2 / 3.3Forum Icons
khekada
Re: Forum Icons
Post by khekada »
Dear Sir
Thnks for this grate extension. I have created some new pictures as icons. Made it transperant png. But all these icons are showing with white background. Any solution ?
Regards
PRADEEP
Re: Forum Icons
khekada wrote: 09 Aug 2016, 12:51 Dear Sir
Regards
PRADEEP
Can you post some of these icons to test?
NavyRet
Re: Forum Icons
Post by NavyRet »
Thanks. This is a super extension. I added icons specific to my forum and they all work great. Thanks again.
Beba
    Mac OS X Safari
Re: Forum Icons
Post by Beba »
Thank you so much! :D
OciXCrom
Re: Forum Icons
Post by OciXCrom »
Any idea why they won't show up on 3.2?
PS: ignore the "forum_icons" path on the image - it's there from the old version. I placed the new ones in the "forumicons" folder.
EnigmaTek
Re: Forum Icons
Post by EnigmaTek »
Does anyone have an easy way to remove the existing forum icons and move everything over to the left?
Re: Forum Icons
EnigmaTek wrote: 15 May 2018, 06:49 Does anyone have an easy way to remove the existing forum icons and move everything over to the left?
Check https://www.phpbb.com/community/viewtop ... &t=2421276 for that.
PS I did not test it..
Re: Forum Icons
OciXCrom wrote: 12 Jan 2018, 20:28 Any idea why they won't show up on 3.2?
So all is ok now?
EnigmaTek
Re: Forum Icons
Post by EnigmaTek »
Thanks DMZX! That worked flawlessly!
Re: Forum Icons
EnigmaTek wrote: 15 May 2018, 12:14
mortalites
Re: Forum Icons
Post by mortalites »
I just setup this extension and its awesome so far but one thing I noticed right away is the Icons are not linkable to the respective forum. It think it would be really nice for users to be able to click the Icon or the Forum text to link to that forum.
Adam,
gpinpin
Re: Forum Icons
Post by gpinpin »
Bonjour
Dommage que cette extension ne soit pas pour phpbb 3.3.
Pourtant elle fonctionne
Gpinpin
translate
Too bad this extension is not for phpbb 3.3.
Yet it works
Re: Forum Icons
All in good time.
Re: Forum Icons
Lets speed this one up on page loading times :whistl:
TWEagle
Re: Forum Icons
Post by TWEagle »
Does it also works in phpBB3.3?
