3.1 & 3.2 Extensions DatabaseForum Goal
Forum Goal
Extension Name: Forum Goal
Author: Stoker extension by dmzx special thanks to martin
The Forum Goal extension display your goals for posts, topics, donation, users and attachments.
Goals can be configured in ACP where you also can enable/disable all features and set the extension to display at the top or bottom of forum index, or both.
Code update for 3.2
ACP=>Board features
Forum Goal v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `forumgoal`.
  4. Copy the `forumgoal` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/forumgoal/composer.json
  6. Look for `Forum Goal` under the Disabled Extensions list, and click its `Enable` link.
This topic has 39 replies
