3.1 & 3.2 Extensions Database 3.1 / 3.2Forum Goal
Forum Goal
Extension Name: Forum Goal
Author: Stoker extension by dmzx special thanks to martin
The Forum Goal extension display your goals for posts, topics, donation, users and attachments.
Goals can be configured in ACP where you also can enable/disable all features and set the extension to display at the top or bottom of forum index, or both.
dmzx/Forum-Goal
Code update for 3.2
ACP=>Board features
Forum Goal v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `forumgoal`.
  4. Copy the `forumgoal` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/forumgoal/composer.json
  6. Look for `Forum Goal` under the Disabled Extensions list, and click its `Enable` link.
alfi0815
Re: Forum Goal
Post by alfi0815 »
I have a problem with this ext.
In my forum only registered members can these ext. see
Where is the error ?
    Windows 8 Chrome
Re: Forum Goal
Open the forum goals body file and remove the first and last green lines and purge the board.
Forum-Goal/styles/prosilver/template/forum_goal_body.html
find and remove <!-- IF not S_IS_BOT and S_USER_LOGGED_IN --> and the very last <!-- ENDIF --> or add a if stament to suit your needs
or replace <!-- IF not S_IS_BOT and S_USER_LOGGED_IN --> with <!-- IF S_INDEX or S_PORTAL -->
alfi0815
Re: Forum Goal
Post by alfi0815 »
:buigen:
    Windows 8 Chrome
Re: Forum Goal
If your view online page is broke as in funny looking css then apply this fix phpBB • [DEV] Forum Goal
cristian
    Windows XP Firefox
Re: Forum Goal
Post by cristian »
Thankyou excellent module
I can help me someone I could make an option to see only the admin site this category?
:sad: :question: help me plisss
Taka51
    Windows Vista Chrome
Re: Forum Goal
Post by Taka51 »
Hello Dmzx
Here is the French translation for this extension installed on my forum and functional
Best regards
Forum_Goal_French_Translation_1.0.0@Taka51_©dmzx.zip
WebDvdBdR - Page d’index
Re: Forum Goal
Taka51 wrote:Hello Dmzx
Best regards
Added :thumbup:
Superl
Re: Forum Goal
Post by Superl »
Thanks for this extension, one question if I want to display file download "attachment" instead of user goal what need to be change. I know how to change the text.
I'm a .net programmer not php :eek:
nelflucifer
Re: Forum Goal
Post by nelflucifer »
Interesting idea! Translations into Russian:
ru.zip
included, but there is no settings in the ACP, is not found.
English Forums
Anuj Dhawan
Re: Forum Goal
Post by Anuj Dhawan »
Installed this extension today but I don't find ACP setting module for it. Can this be conflicting with some other extension?
Re: Forum Goal
Read the first post again
ACP=>Board features
Anuj Dhawan
Re: Forum Goal
I might have had momentarily brain failure and missed that part of the post... . Thanks, got it now.
Anuj Dhawan
Re: Forum Goal
100% does not look correct!?
Re: Forum Goal
Check if there are users that need to be activated.
