3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Image Upload
Puchahawa
Re: Image Upload
Nicely done on the multiple delete and sort options DM!
DKBjorn
- Translators
Re: Image Upload
I just installed this extension for first time, use phpbb3.2
I have no submit button... anyone have a little hint for fix.....?
Re: Image Upload
Set group permissions
admins can use with out setting perms but check it any way.
just a thought are you using a theme other than prosilver and where is it you dont see the button ?
index page will be in the navbar and posting pages there will be a inline button (i get the feeling your not using prosilver)
Edit i see your using prosilver can you pm me a test account pls
DKBjorn
- Translators
Re: Image Upload
i have sent you a PM.. with login details.... im in chat on my site.......martin wrote: 09 Feb 2017, 19:01 set group permissionsadmins can use with out setting perms but check it any way.
Re: Image Upload
Will post a fix for you and others in this topic
dodgy dutch coding of forum creator
DKBjorn
- Translators
Re: Image Upload
Many MAny Thx.....martin wrote: 09 Feb 2017, 20:47 Will post a fix for you and others in this topicdodgy dutch coding of forum creator
Puchahawa
Re: Image Upload
Hey guys, what would it take to change it so a mbr adding an image is put in the users log instead of the admin log? Kind of like to have the admin log be more along the lines of ext updates and board mngt stuff. Or maybe an option to not have images logged at all. They show on the extensions config page so not sure I need to know about it on a log. Just askin.
Re: Image Upload
I tested it now and it is very useful! Thank you for this great extension.
I notice some problems with styling. If you use e.g. black or dark coloured styles it overwrites your colours.css for .panel, h2 and fieldset - you can not read the codes. I am not a styler, so I am trying and trying and can not find the right css. Is it possible to use other not standard classes for this extension? Or to change the standard classes to better work with light and dark styles inheriting the colour sets?
panel colours are e.g. correct but in image upload - using .panel bg2-
Re: Image Upload
It's made for prosilver (light colour) so yes when on darker boards it prob will not look so nice if you get stuck pm me a test account and one that can use the uploader and il post new css for dark styles.
Or maybe a link to your style and il do it on localhost.
Hows this ? This will give you black text in the input box's
css for the ext
css for the ext
.codes {
display: block;
width: 100%;
overflow: scroll;
white-space: nowrap;
height: 2.5em;
font-size: 100%;
color: #ECF1F3;
border: 1px solid #000;
#codes input{
width: 99%;
.icon-upload {
background-image: url("./images/icon_upload.png");
#upload {
max-width: 100%;
height: auto;
#showdiv {
text-align: center;
#codehtml {
font-weight: bold;
input {
font-weight: normal;
vertical-align: middle;
padding: 0 3px;
font-size: 1em;
font-family: Verdana, Helvetica, Arial, sans-serif;
color: #000000;
}You do not have the required permissions to view the files attached to this post! Maybe your post count is too low.
Re: Image Upload
Yes, I get this problem with a lot of your extensions
All fixed to light styles - not good. Some people like black styles.
Ok - I was successful here with:
Now I am messing around with Navbar... the same problem - and it does not have the same size as the other dropdowns...
Thank you, martin.
.codes {
display: block;
width: 100%;
overflow: scroll;
height: 2.5em;
font-size: 100%;
color: #080808;
#codes input{
color: #000000;
width: 99%;
.icon-upload {
#upload {
max-width: 100%;
height: auto;
#showdiv {
text-align: center;
#codehtml {
font-weight: bold;
Thank you, martin.
Re: Image Upload
I do the light style Martin is bit darker...
Re: Image Upload
Can you post a link to your theme ?
killfrenzy
Re: Image Upload
I have problem with image after upload it doesn't show only blank image?
Visit my blog http://androidcribs.com Androidcribs.com
