Ok I see, place the code back in socialbuttons and delete the code in countdownheader I adjusted this post viewtopic.php?p=13420#p13420
3.1 & 3.2 & 3.3 Extensions Database 3.1 / 3.2 ⇒ Countdown Header
Re: Countdown Header
caju
Hello dmzx, thanks for this great extension :)
After updating to 1.0.2, when I try to enable the countdown, I get the following error in my javascript console (Google Chrome):
Any idea to fix this?
Kind regards,
jquery.min.js:2
Uncaught Error: Method 1494428400000 does not exist in the jCountdown Plugin
at Function.error (jquery.min.js:2)
at n.fn.init.a.fn.countdown (eval at <anonymous> (index.php:1), <anonymous>:1:4783)
at HTMLDocument.<anonymous> (index.php:1936)
at j (jquery.min.js:2)
at Object.fireWith [as resolveWith] (jquery.min.js:2)
at Function.ready (jquery.min.js:2)
at HTMLDocument.K (jquery.min.js:2)Kind regards,
caju
Good guess!! :)
Just searched for extensions with "count" on name, and realized that the one called "Member time counter" was the culprit.
Thanks, martin, for the guess.
If you want to run both ext's do this
open /ext/dmzx/countdownheader/styles/prosilver/template/event/overall_footer_after.html
Now replace the code in the file with this
purge the boards cache and your browser this will make it run on the index only.
<!-- IF SCRIPT_NAME == "index" and COUNTDOWNHEADER_ENABLE -->
<!-- INCLUDEJS jquery.jcountdownheader.min.js -->
$(function() {
var $timerBox = $('#countdown-timer');
$timerBox.html('<span class="timer-big"></span><span class="timer-small"></span>');
var $timerBig = $timerBox.find('.timer-big');
var $timerSmall = $timerBox.find('.timer-small');
var number = '';
var unit = '';
var utc = new Date('{COUNTDOWNHEADER_DATE}').getTime();
$timerBox.countdown(utc).on('update.countdown', function(event) {
if (event.offset.totalDays > 0) {
number = event.strftime('%D');
unit = '{LA_COUNTDOWNHEADER_COUNT_DAYS}';
} else if (event.offset.hours > 0) {
number = event.strftime('%H');
unit = '{LA_COUNTDOWNHEADER_COUNT_HOURS}';
} else if (event.offset.minutes > 0) {
number = event.strftime('%M');
unit = '{LA_COUNTDOWNHEADER_COUNT_MINUTES}';
} else if (event.offset.seconds > 0) {
number = event.strftime('%S');
unit = '{LA_COUNTDOWNHEADER_COUNT_SECONDS}';
$timerBig.html(number);
$timerSmall.html(unit);
}).on('finish.countdown', function() {
$timerBig.html('{COUNTDOWNHEADER_TEXT_BIG}');
$timerSmall.html('{COUNTDOWNHEADER_TEXT_SMALL}');
$timerBox.attr('href', '{COUNTDOWNHEADER_URL}');
$timerBox.show();
</script>
<!-- ENDIF -->-
miri4ever
I'm more having the problem the counter is display nowhere at any kind of style I'm testing.
Funny
- New user
I use the XMAS counter because you can adjust a whole lot.
The counter header I have also installed but prefer the XMAS
mg Funny
mg Funny
Scrugio
Is it possible to add an option in configeration to change the colours ?
have changed the style using Hexagon style and all users can see is the numbers
Its default for prosilver but you can add a folder in styles call All and then a theme folder then a css file for it and copy the porsilver css into it then change the colours to your liking
Scrugio
Thanks will have a crack at it next week when im off work againmartin wrote: 03 Aug 2017, 17:34 Its default for prosilver but you can add a folder in styles call All and then a theme folder then a css file for it and copy the porsilver css into it then change the colours to your liking
el torro
Hi, is it difficult to put the bar above the footer?
AHartenheer
