3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Member Profile Views
Kim
Re: Member Profile Views
Russian for 1.0.2
Cuilibet fatuo placet sua clava.
rogerio24
Is there the spanish version?
The Good
Need help plz
why I have all this code ??
phpbb prosilver 3.1.9
thx
thx
BLIZZARDCZ
today I made the update to version 1.0.2 but do not see no avatar or number of views for each user.
Do you know včem could be wrong ?
blizzard
my version phpbb on 3.1.9
blizzard
Wolfkin48
Is there any way to alter the extension (or the existing code) so that the information will be shown only to the owner of the profile?
The Good
still no support !!The Good wrote: 21 Aug 2016, 19:57 need help plz
thx
Member Profile Views 1.0.3 phpbb 3.1.10
mortalites
Is there by chance any way to change the last 100 Members to say 25 or 50 members. I looked through all the posts but I didnt see anyone ask about this.
In the migration schema file it adds a new column to the config table.
You could go to phpmyadmin and look in the config table and change the value of profileviews_value column to 25 or 50.
I don't understand this:
// Add configs
array('config.add', array('profileviews_value', 100)),In the memberlist_view_contact_after.html template is this url written right for that link?
<div class="member-viewed-avatar">{member_viewed.AVATAR}</div> <span><a href="{member_viewed.URL}" "{member_viewed.TIME}" ""{member_viewed.USERNAME_COLOUR}">{member_viewed.USERNAME}</a> ({member_viewed.COUNTER})</span><!-- IF not member_viewed.S_LAST_ROW -->, <!-- ENDIF -->Code: Select all
<a href="{member_viewed.URL}" "{member_viewed.TIME}" ""{member_viewed.USERNAME_COLOUR}">-
Did you check ACP settings to enter a value?mortalites wrote: 20 Nov 2018, 23:25 Is there by chance any way to change the last 100 Members to say 25 or 50 members. I looked through all the posts but I didnt see anyone ask about this.
Ah... I see it now, in ACP / Board features / under Load settings. I was like mortalites, didn't know that was there.
Maybe add a screenshot of acp setting on first post. I just now saw the Added ACP option to set value (Board features)
And I understand your link now.
You set those up in the listener, I've never seen that done before.
What planet do you hail from?
<a href="{member_viewed.URL}" "{member_viewed.TIME}" "{member_viewed.USERNAME_COLOUR}">{member_viewed.USERNAME}</a>Code: Select all
$user_colour = ($totalviewsmember['user_colour']) ? ' style="color:#' . $totalviewsmember['user_colour'] . '" class="username-coloured"' : '';
$user_time = ($totalviewsmember['date']) ? ' title="' . $this->user->format_date($totalviewsmember['date']) . '': '';-
Check listener and comment out this line:
'COUNTER' => $totalviewsmember['counter_user'],
