3.2 & 3.3 Extensions Database 3.2 / 3.3Ultimate Points Extension
0 given 1
Re: Ultimate Points Extension
Solidjeuh wrote: 02 Aug 2018, 19:54
ivailo95 wrote: 02 Aug 2018, 16:35
Solidjeuh wrote: 02 Aug 2018, 15:58 All errors are solved, installed on my test forum few weeks ago and see no problems.. Thank you :)
try to reset lottery history and user logs if there is errors :roll:
Done, no errors. All works here :eyes2:
https://youtu.be/g3CT8f2PQ8E :roll: :eyes2: :question:
ivailo95 wrote: 03 Aug 2018, 11:01
Fell asleep watching the video :whistl:
As I said before, no problems here.
0 given 1
As you can see the video..i saw some errors..
A
MadameSativa
Post by MadameSativa »
How to put only number without "decimals" in viewtopic? :eyes2:
scriptman
Post by scriptman »
Can we have a referral system for this extension please?
skuadsco
Post by skuadsco »
It did not work on phpbb3.2.2. It not show in the extension inside the admin panel
0 given 1
skuadsco wrote: 05 Sep 2018, 17:16 It did not work on phpbb3.2.2. It not show in the extension inside the admin panel
are you sure place it in right way?
The right way to place is: Creare folder with name dmzx (if u haven't it) then re-name second folder to ultimatepoint
or u can see file json.php
When i see my ftp i will wrote u correct way to place it on ur ftp to see in ur acp
EDIT:
1st. Download it
2nd. re-name folder "ultimatepoints_v122" to "ultimatepoints"
3rd. Create folder in your ftp with name "dmzx" then place folder "ultimatepoints" in ur crated folder "dmzx" then go to ACP :thumbup:
theia
    Windows 10 Internet Explorer
Post by theia »
Thank you about your work. I was fall in love about Utimate points. Great works.
Now i'll waiting shop extension (i'm a newbie, i'm afraid of MOD installation lol). Sorry about my bad English, i'm french.
@All : Make a crowdfunding for Utimate Shop Points developpement priority and just about me i'm ok to donate about this projet :whistl: :mml:
3 given 0
Still the shop is one of my todo things.
And will work on it. :thumbup:
NAPWR
    Windows XP Chrome
Post by NAPWR »
dmzx wrote: 08 Sep 2018, 22:22 Still the shop is one of my todo things.
Will be the best Shop out there DM thanks :eusa_dance: :dance: :mml:
My name is Dave I, and all things are out there, and we are in here :mml:
theia
Post by theia »
@dmzx : Thx about reply my post :)
Wish there are not too much projects on your todo list before the Shop :eusa_dance:
Venatus Vinco
Post by Venatus Vinco »
Fantastic extension!
Is there a way to display all transactions...kind of like a global log?
I see that you can output transactions into mchat so perhaps something more static is possible as well? Maybe as an MCP module?
I might be in a position to fund this add-on.
Many thanks.
VV
Restless Rancor
Post by Restless Rancor »
Hi, thanks for bringing this over to 3.2, I used the 3.0 modification a lot. I've posted this in the phpbb dev topic, but I know some extension authors check in more at their own forums so have posted it here too. Apologies if I shouldn't have, I'm just keen to use this extension!
I don't remember if the 3.0 modification had this feature, but is it possible to do a mass recalculation of user points?
This would be so I can install it onto a board and award every member the correct amount of points according to their forum history, as if the extension was active since day 1.
Also I've noticed when the Bank is disabled it still shows Bank information on a member's profile, I'm not sure if that's how it's supposed to function?
Venatus Vinco
Is there any way to make points sent to a Usergroup via PM in the ACP show up in the logs?
Thanks!
VV
luca17000
Post by luca17000 »
I have this message When you turn on the extension
Fatal error: Uncaught exception 'phpbb\module\exception\module_exception' with message 'CANNOT_REMOVE_MODULE' in /home/clients/2e8d92eb8d13513ea97c3f40a629d001/web/Jeu/phpbb/module/module_manager.php:448 Stack trace: #0 /home/clients/2e8d92eb8d13513ea97c3f40a629d001/web/Jeu/phpbb/db/migration/tool/module.php(425): phpbb\module\module_manager->delete_module(937, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #2 /home/clients/2e8d92eb8d13513ea97c3f40a629d001/web/Jeu/phpbb/db/migration/tool/module.php(459): call_user_func_array(Array, Array) #3 [internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #4 /home/clients/2e8d92eb8d13513ea97c3f40a629d001/web/Jeu/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5 /home/clients/2e8d92eb8d13513ea97c3f40a629d001/web/Jeu/phpbb/db/migrator.php(683): phpbb\db\migrator->run_step(Array, false, true) #6 /home/clients/2e8d92eb8d13513ea97c3f40a629d001/web/Jeu in /home/clients/2e8d92eb8d13513ea97c3f40a629d001/web/Jeu/phpbb/module/module_manager.php on line 448
any idea?
Best regards
