Install the 1.0.5 version.
3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Image Upload
Re: Image Upload
Version 1.0.4 does not include the version ssl check.
Re: Image Upload
Thank you for the update. Fine that we can delete images now
Unfortunately it seems not to solve the problem with mixed language in ACP.
I am sure now it is something with Collapsible Categories (phpBB Extension v. 1.0.2 from CDB) and Image Upload or another of your extensions together. May be Quotes Collection? Is collapsible, too.
All is fine as long I do not activate Collapsible Categories together with one of yours. Seems, there is another conflict (classes?). If I deactivate your extensions OR Collapsible Categories the mixed language ist gone. Strange.
I researched for error messages with my browsers inspector and found:
Here the updated german language files
Don't know what that means, but I hope it helps to find the conflict.ReferenceError: reference to undefined property "expando"
jquery.min.js:3:4174
ReferenceError: reference to undefined property "nodeName"
jquery.min.js:2:31306
SyntaxError: applying the 'delete' operator to an unqualified name is deprecated
admin.js:13:8
ReferenceError: reference to undefined property "jQuery111009666297325613871"
jquery.min.js:2:31950
ReferenceError: reference to undefined property "triggered"
jquery.min.js:3:6403
ReferenceError: reference to undefined property "undefined"
jquery.min.js:3:563
jquery.min.js:3:4699
ReferenceError: reference to undefined property "result"
jquery.min.js:3:8206
Source-Map-Fehler: TypeError: NetworkError when attempting to fetch resource.
Ressourcen-Adresse: moz-extension://7aa2264d-b569-491c-91cd-3e6d53212ca2/content/js/purify.min.js
Source-Map-Adresse: purify.min.js.map
Re: Image Upload
Re: Image Upload
I noticed: if you give to a group following permissions:
can upload images - no/never
can delete images - yes
the user can not see the images he has uploaded and delete them. Would be fine if you can change it.
With GDPR it is better he can. He don't need to upload new images, but he must be able to delete his own stuff at every time.
Re: Image Upload
Ok to fix it:Scanialady wrote: 18 Apr 2018, 20:00 I noticed: if you give to a group following permissions:
imageupload_info.php
'auth' => 'ext_dmzx/imageupload && acl_u_image_upload',Replace with Replace the preceding lines with the following
'auth' => 'ext_dmzx/imageupload',Will remove it in next release also.
Re: Image Upload
Suggestion:
Add check box here some stuff
check box
Scroll down
Options: Mark all , Unmark all
Delete marked
users can delete more than one picture at once
check box
Scroll down
Delete marked
Re: Image Upload
The imageupload_info.php is there twice - acp and ucp. Have I to change both or only UCP?dmzx wrote: 19 Apr 2018, 10:07Ok to fix it:Scanialady wrote: 18 Apr 2018, 20:00 I noticed: if you give to a group following permissions:
imageupload_info.phpFind This may be a partial find and not the whole lineCode: Select all
'auth' => 'ext_dmzx/imageupload && acl_u_image_upload',Reinstall the ext.Replace with Replace the preceding lines with the followingCode: Select all
Re: Image Upload
Hmm...ok, seems not to work with deactivate/activate - user can still not see his images. Delete data would delete all images we have now, I think.
Thats not the best idea. But thanks for your answer.
Re: Image Upload
to evade deletion of all image you uploaded just deactive this ext and upload newest version then active it againScanialady wrote: 21 Apr 2018, 12:47 hmm...ok, seems not to work with deactivate/activate - user can still not see his images. Delete data would delete all images we have now, I think.Thats not the best idea. But thanks for your answer.
Re: Image Upload
As you quoted: thats what I have done ;-)
rammstein
Re: Image Upload
I have a draper in Image Upload
B Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 263: getimagesize(./ext/dmzx/imageupload/files/b2b94c7f25128748cc0c8a1ff83ea3f8.png): failed to open stream: Permission denied
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/imageupload/event/listener.php on line 263: getimagesize(./ext/dmzx/imageupload/files/602ff6074267f6de68377d7c080f3688.jpg): failed to open stream: Permission denied
Warning: in file [ROOT] /ext/dmzx/imageupload/controller/imageupload.php on line 223: getimagesize (./ ext / dmzx / imageupload / files // 3cd4192c1674a05083506f15eecc105a.png): failed to open stream: Permission denied
who do you mean?
who do you mean?
vfrblue
Re: Image Upload
I have a little problem with "Image Upload". If a user changes his board language, not all extensions and areas are translated. For example, "Board-Index", "Who is online" and "Quick links" remain in the system language (in this case German).
If I deactivate "Image Upload", everything is displayed correctly. The conflict exists with the extension "Collapse Forum Categories" by "phpBB". If this Ext. is deactivated, everything is also displayed cleanly.
Translated with www.DeepL.com/Translator
Re: Image Upload
I reported the same problem here:
Image Upload
