3.2 & 3.3 Extensions Database 3.2 / 3.3Browser & OS in Viewtopic
Peralta
Re: Browser & OS in Viewtopic
Post by Peralta »
Proper Windows 10 detection
ext/dmzx/browsericon/includes/user_agent.php
Search:
		elseif (substr($version, 0, 3) == 10)
			if (substr($version, 0, 3) == 10.0)
				$system = 'Windows 10';
Replace with:
		elseif (substr($version, 0, 2) == 10)
			if (substr($version, 0, 4) == 10.0)
I overwrote your ext/dmzx/browsericon/images/user_agent/unknown.png with this image:
It looks so much better in the posts.
playgoods
Post by playgoods »
Thank you. For older posts is it possible to have nothing instead of a ? mark sign.
Only new posts will show something
verlinur
    Windows 7 Internet Explorer
Post by verlinur »
I made this post with Win7 and IE11, but shows that i have Mozilla 5, can you fix this?
Null
Post by Null »
If moderator change a message, extension will update to browser and OS moderator infornation. Shouldnt keep original poster information?
Yes user_agent will be taken from last edit in post.
Cyber Man
    Windows 8.1 Firefox
Post by Cyber Man »
Hi friends,
:question: Is this compatible with v3.1.6?
Because I tired to use as a ext (& it has enabled in acp). but not yet display with, after wrote some new-posts too..
please reply me..
http://www.webhostingtalk.lk
thank you for your valuable time...
Yes this should work with 3.1.6, did you logout an login again after enable the extension :question:
Cyber Man
    Windows 8.1 Firefox
Post by Cyber Man »
Yes, I have done several times after your reply .. & purged the cache too. But it isn't working yet.
Have any configuration-settings to config in ACP?
(if yes, mention the path please..)
thank you!
It works right out of the box on 3.1.6
I suggest you go into firefox setting and delete the browser cookies and see.
Pls unistall the ext and delete the data and try this ext pls its the same ext but with a small change.
dmzx-Browser-and-OS.zip
Cyber Man
    Windows 8.1 Firefox
Post by Cyber Man »
:mml: I've installed this new one..
Perfect... It's working well... thank your for your great support..
Yw would you like to know the fix ??
Ext's think your using prosilver so only tend to install on that.
Dam ext creators should be using the style path all not prosilver but phpbb like you to use prosilver so remember if you install a ext and see nothing then change the styles/prosilver to styles/all and look inside the styles folder for any path related to prosilver and change the word prosilver to all :rolling:
simples
Cyber Man
    Windows 8.1 Firefox
Post by Cyber Man »
:buigen: OK, I will next time.. thnx again..
Three of my ext use all for the style but the mobile ext says prosilver. I think dmzx forced me to use that, not sure. :whistl:
