3.1 & 3.2 Extensions Database 3.1 / 3.2 ⇒ Statistics on Index
Re: Statistics on Index
Just comment out what you dont need i have lol.
see here guests can see stats http://www.martins.homelinux.net/sub/index.php
Tarantino
Yup. That's what I said.
[ Post made via OnePlus One ]
Sinister Smile
I get this error :/ Im using phpbb 3.1.10
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/statsonindex/event/listener.php on line 58: Division by zero
wads24
I don't have that extension, but I'm seeing this alsodmzx wrote: 16 Nov 2015, 18:59Switch off newest members extension.moffacostanzo wrote:hi
i installes this extension
how can i hide the first statistic ( i have two voice)
Fezroux
After installing this, the stats are now no longer visible to guests. I was wondering if it's supposed to be this way or if it's a problem on my end. Either way, how do I fix it?
Fezroux
Why isn't this viewable to guests?! I'd really appreciate it If this could be done.
Look at the html file your see a ifstatement there for logged in users only.
Fezroux
Hey thanks for the reply. Can you elaborate a little more on what exactly needs to be changed? Looking at the files I'm assuming you're referring to the index_body_stat_blocks_after.html one? It appears I need to change the first line, but what change do I need to make to it?
Yes, do you see the first line? <!-- IF not S_IS_BOT and S_USER_LOGGED_IN -->
Change that line to <!-- IF not S_IS_BOT -->
Fezroux
Hey great, that did it.
Also, I installed the version with the time online counter, and noticed it isn't correct. It's two days off. I tested it against other stat extensions that contain the same feature, and they correctly calculated the time. It's not that big of a deal, I just figured you would want to know.
Mickroz
Needs updating for phpBB 3.3 (single quotes in services.yml)
Q: Whats a hash and a root password?
A: hash gets you high, root password gives you god powers, combine the 2 and you are invincible.
