3.2 & 3.3 Extensions Database 3.2 / 3.3Pay for download
francesca
Re: Pay for download
Post by francesca »
Thank you Hamidouki-dz but make an upload button here
Dont put you downloads in the ext you loose them on updates il post how to add the upload in the morning.
francesca
Post by francesca »
Hello no one to help me with my question ?
Download the file upload ext viewtopic.php?f=66&t=2470 install it and set it to admin only use then replace the payfordownload_input_link.html code with this.
<div class="inner">
	<p><h3>{{ lang('PAYFORDOWNLOAD_LINK_ADD_TITLE') }}</h3></p>
	<fieldset class="fields2">
		<dl>
			<dt><label for="payfordownloadlink">{{ lang('PAYFORDOWNLOAD_LINK_ADD_TITLE_BOX1') }}</label></dt>
			<dd>{% if FILEUPLOAD_USE_UPLOAD and S_ACCESS %}
<button	class="button" class="button2" onclick="popup('./fileupload', 700, 800); return false;" value="{{ lang('FILEUPLOAD_UPLOAD') }}" title="{{ lang('FILEUPLOAD_UPLOAD') }}" />
<i class="icon fa fa-files-o" aria-hidden="true"></i><span class="sr-only">{{ lang('FILEUPLOAD_UPLOAD') }}</span>
</button>
{% endif %}<input type="url"  name="payfordownloadlink" id="payfordownloadlink" class="inputbox"><i class="buttoncopy" data-copytarget="#payfordownloadlink">{{ lang('PAY_COPY') }}</i></dd>
		</dl>
		<dl>
			<dt><label for="payfordownload_credits">{{ lang('PAYFORDOWNLOAD_LINK_ADD_TITLE_BOX2') }}</label></dt>
			<dd><input type="number" min="1" max="1000" name="payfordownload_credits" id="payfordownload_credits" value="40" class="inputbox autowidth">{{ lang('PAYFORDOWNLOAD_LINK_ADD_TITLE_BOX2_EXPLAIN') }}</dd>
		</dl>
		{% if S_ACCESS %}
		<dl>
			<dt><label for="payfordownload_owner">{{ lang('PAYFORDOWNLOAD_LINK_ADD_TITLE_BOX4') }}</label></dt>
			<dd><input type="text" name="payfordownload_owner" id="payfordownload_owner" maxlength="255" value="{{ USERNAME }}" class="inputbox" style="max-width: 40%;"></dd>
		</dl>
		<dl>
			<dt><label for="payfordownload_find_username"></label></dt>
			<dd><input type="button" id="payfordownload_find_username" value="{{ lang('FIND_USERNAME') }}" class="button2" onclick="find_username('{{ U_FIND_USERNAME }}'); this.blur(); return false;"></dd>
		</dl>
		{% endif %}
	</fieldset>
	<fieldset class="submit-buttons">
		{% if S_ACCESS %}
		<input type="button" value="{{ lang('PAYFORDOWNLOAD_LINK_ADD_BUTTON') }}" class="button1" onclick="Reload_Body('{{ U_MAKE }}&payfordownloadlink='+encodeURIComponent(document.getElementById('payfordownloadlink').value)+'&payfordownload_credits='+document.getElementById('payfordownload_credits').value+'&payfordownload_owner='+document.getElementById('payfordownload_owner').value,'payfordownloadcontent');">
		{% else %}
		<input type="button" value="{{ lang('PAYFORDOWNLOAD_LINK_ADD_BUTTON') }}" class="button1" onclick="Reload_Body('{{ U_MAKE }}&payfordownloadlink='+encodeURIComponent(document.getElementById('payfordownloadlink').value)+'&payfordownload_credits='+document.getElementById('payfordownload_credits').value,'payfordownloadcontent');">
		{% endif %}
		<hr class="dashed">
	</fieldset>
	<p>{{ lang('PAYFORDOWNLOAD_LINK_ADD_EXPLAIN') }}</p>
</div>
{% INCLUDEJS '@dmzx_payfordownload/js/copy.js' %}
francesca
Post by francesca »
Thank you very much martin :wink:
Disable the button on posting pages and keep it for admin too as later in life you may run into issues. :whistl:
francesca
Post by francesca »
Thank you :tumbsyes: :wink:
Maclobster
Post by Maclobster »
Thanks :tumbsyes: :eusa_dance:
“A man searching for the Lost Paradise, can seem a fool to those who never sought the other world.”
-JM
The Good
Post by The Good »
Hi.. I want to try..
the file should be hosted in forum server or can be as link exp www.mediafire.com ?
The Good wrote: 17 Aug 2021, 13:54 Hi.. I want to try..
it can be any link, on server or outside server.
jordon
Post by jordon »
Hello, what extension do I need to pay?
jordon wrote: 19 Dec 2021, 20:43 Hello, what extension do I need to pay?
