3.3.x Extensions Database 3.2 / 3.3 ⇒ Watermark
Re: Watermark
No need for author as your uploading to a site so it gets the sites watermark.
Just installing another server so i can run 3.2 on a lower php.
The Good
Re: Watermark
why I am asking about author.. just when its happen.. years or months later when photos go to google taking by other persons.. they will be able to know the author if they publish your stuff in forums so they will be able to say in post credit goes to original author (name)martin wrote: 05 Jun 2020, 20:31 No need for author as your uploading to a site so it gets the sites watermark.
Re: Watermark
But look at the image below if its used on any other site they will see where it came from and maybe join up
cant join a site based on a users name.
and an image from my site
Re: Watermark
Omg omg cool extension
nice work
Re: Watermark
It's in the 3.3 section thats a clue.
Cliff Evans
- Donator
Re: Watermark
Is there a way of moving the watermark to a different position on the picture?
Re: Watermark
For now not maybe in next release I will build that.Cliff Evans wrote: 21 Jun 2020, 12:57 Is there a way of moving the watermark to a different position on the picture?
Cliff Evans
- Donator
Re: Watermark
Thank you, it would be a good option.
Re: Watermark
Is there any option to add watermark to image upload?
when i upload image add also and watermark to uploaded images
thanks in advance
thanks in advance
Re: Watermark
This in indeed an option in next release of that extension, but this topic is not for image upload extension.ivailo95 wrote: 22 Jun 2020, 10:32 Is there any option to add watermark to image upload?
thanks in advance
alex75
Re: Watermark
Hi. Here is the Italian translation.
but it doesn't work for my 3.3.0 test forum
I can't load the watermark image. I'm getting this error:
I tried to create the "watermark" folder on the root and also under the images folder. What am I missing?
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/watermark/controller/acp_controller.php on line 207: move_uploaded_file(....phpbb-store....../test330/images/watermark/watermark.png): failed to open stream: HTTP wrapper does not support writeable connections
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/watermark/controller/acp_controller.php on line 207: move_uploaded_file(): Unable to move '/tmp/phpOP2dcW' to '.......phpbb-store....../test330/images/watermark/watermark.png'You do not have the required permissions to view the files attached to this post! Maybe your post count is too low.
Re: Watermark
It makes its own folder with your uploaded image in and inserts that link to your images.
alex75
Re: Watermark
With your advice, the error has disappeared. But even writing the full url I don't see the watermark
Re: Watermark
Pls read the text on the acp page why have you a full link to image ?
remove the link and use only the image name.
