Extensions Database 3.2 / 3.3 ⇒ 3.2 & 3.3 Delete Inactive Users
Re: Delete Inactive Users
eunaumtenhoid
If the user is active but has 0 posts will he be deleting?
could have option to turn on 0 posts and another to turn on last activity date
before deleting the user could send an email to him
To my opinion a member is active when he will post also, I dont see any active members with 0 posts and only come to download all downloads and go away and never come back.eunaumtenhoid wrote: 09 Aug 2019, 14:15 if the user is active but has 0 posts will he be deleting?
So to those members the 0 post is perfect to remove them from the board.
1. User need to make 1 post (topic) to not deletedeunaumtenhoid wrote: 09 Aug 2019, 14:15 if the user is active but has 0 posts will he be deleting?
- There is message after registration message that they need to be active and post 1 topic
eunaumtenhoid
but if i mark 1 post all user with 1posts or less will be deletedivailo95 wrote: 09 Aug 2019, 14:191. User need to make 1 post (topic) to not deletedeunaumtenhoid wrote: 09 Aug 2019, 14:15 if the user is active but has 0 posts will he be deleting?
0 post then bye bye there not an active user they have joined to leech files aka grab and run no one wants a huge database of users who dont take part in any way.
You can create a topic (make it global topic/important) and tell them that ur user need to post under ur topic to hold their accounts
No need to wait for the update there see a message.ivailo95 wrote: 09 Aug 2019, 14:23 You can create a topic (make it global topic/important) and tell them that ur user need to post under ur topic to hold their accounts![]()
eunaumtenhoid
But if i mark 1 post all user with 1posts or less will be deleted?
eunaumtenhoid wrote: 09 Aug 2019, 14:27 but if i mark 1 post all user with 1posts or less will be deleted?
See Martin's imagemartin wrote: 09 Aug 2019, 14:22 0 post then bye bye there not an active user they have joined to leech files aka grab and run no one wants a huge database of users who dont take part in any way.
eunaumtenhoid
I understand, only ser group user newster and problem solved tks guys
eunaumtenhoid wrote: 09 Aug 2019, 14:56 I understand, only ser group user newster qnd problema solved tks guys
eunaumtenhoid
But why say 1 topic and no 1 post?
Yes can be indeed also 1 post, just change the language file if you want that.
