Christmas day for russian orthodoxesproavia wrote: 14 Dec 2016, 00:51 I like the idea of having the countdown in the header!![]()
BTW - 25 days until I can go get what???![]()
Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 & 3.3 Countdown Header
Nully
Re: Countdown Header
iorG19
- Translators
it's also usefull for other events
when i activate the ext, my board index doesn't work. But, the ACP yes it does. Why ?
Switch off phpBB counter to test.iorG19 wrote: 17 Dec 2016, 16:57it's also usefull for other events
iorG19
- Translators
Nope; problem persist! With test mode enabled or disabled, the same think!
iorG19
- Translators
yes i do!dmzx wrote: 18 Dec 2016, 09:09 Did you disable the phpBB Countdown extension in ACP ?
You need to disable it complete.
iorG19 wrote: 17 Dec 2016, 16:57 when i activate the ext, my board index doesn't work. But, the ACP yes it does. Why ?
Wait dont switch off that extension for sure it will not work
You posted the above link f your forum, are you not testing there?
On that index I see phpBB Countdown that is a different extension that one you must switch off not Countdown Header
moffacostanzo
If i aneble this ext on my board apperas a double search
Do you have other extensions on that replace the search box?moffacostanzo wrote: 19 Dec 2016, 11:52 if i aneble this ext on my board apperas a double search
moffacostanzo
Dmzx/socialbuttons
i have a problem with this ext
Open in dmzx/countdownheader/styles/prosilver/template/event the overall_header_breadcrumbs_after.html and delete all code there and save.
Clear cache.
moffacostanzo
ok function but i see it in this mode
