Just noticed that this extension has some very strange conflict on my 3.1.10 forums: registered users dont see section "Users browsing this forum"
Have you seen something similar before?
Thanks!
Extensions Database 3.1 / 3.2 ⇒ 3.1.x Hide Index Info
blowj
Re: Hide Index Info
Please fix Absolution theme
Thank You!!
Thank You!!
SergeiS
Re: Hide Index Info
Just in case you have time and willingness to help on this issue:SergeiS wrote: 18 Nov 2016, 22:19 Just noticed that this extension has some very strange conflict on my 3.1.10 forums: registered users dont see section "Users browsing this forum"
Thanks!
link to test forum with same problem http://dev.striborg.ee/test308upgrade/
user: test308 / test1234
Re: Hide Index Info
THX for thistaledus wrote: 29 Jun 2016, 16:52 I had an issue with using this extension and displaying the Statistics section twice when using Statistics on Index extension. I commented out the first Statistics section since the information there already displayed on Statistics on Index.
/ext/dmzx/hideindexinfo/styles/prosilver/template/event/index_body_stat_blocks_after.htmlIt can probably be deleted though.Code: Select all
<!-- <!-- IF NEWEST_USER and S_USER_LOGGED_IN --> <div class="stat-block hidestatistics"> <h3>{L_STATISTICS}</h3> <p> <!-- EVENT index_body_block_stats_prepend --> {TOTAL_POSTS} • {TOTAL_TOPICS} • {TOTAL_USERS} • {NEWEST_USER} <!-- EVENT index_body_block_stats_append --> </p> </div> <!-- ENDIF --> -->
Xxxbennyxxx
Re: Hide Index Info
There will be an update 3.2?
SergeiS
Re: Hide Index Info
Is anyone tested this on 3.3? I would love to get this after update ;)
- Banned
Re: Hide Index Info
Yes of course works fine with 3.3.3 version of phpBB
