Yeah, but I have that "dot' at the left side thendmzx wrote: 05 Mar 2017, 21:04 So did you change overall_header_breadcrumbs_after.html to overall_header_navbar_before.html ?
3.1 & 3.2 Extensions Database 3.1 / 3.2 ⇒ New Topic
Re: New Topic
Re: New Topic
When you use overall_header_navbar_before.html
Replace in new_topic.html
<select onchange="document.location.href = this.options[this.selectedIndex].value;"><option value="-1">{L_NEW_TOPIC_SELECT}</option>{EXT_NEW_TOPIC}</select>-
Re: New Topic
Like this then, because it was not completely on the ride sidedmzx wrote: 05 Mar 2017, 21:18 when you use overall_header_navbar_before.html
Replace in new_topic.htmlCode: Select all
<div align="right"><select onchange="document.location.href = this.options[this.selectedIndex].value;"><option value="-1">{L_NEW_TOPIC_SELECT}</option>{EXT_NEW_TOPIC}</select></div>
Thank you
khurrammunawar
Re: New Topic
Still not working for newly registered users. ( user subject to post approval )
Re: New Topic
Idea: changeable width
[ Post made via Android ]
