Yes thats true
3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Member Profile Views
uruguayito
- Donator
Re: Member Profile Views
Thx
Sorry for my bad English.
I'm a latin american man.
Spanish is my language.
Siava
Hi! Thanks for this extension!
I added a counter per user like on this forum:
in listener.php
find
replace with
find
after add
find
after add
fix current view count
find
replace with
memberlist_view_contact_after.html
find
replace with
in listener.php
find
$query = "SELECT m.user_id, u.username, u.user_colour, u.user_idCode: Select all
$query = "SELECT m.user_id, u.username, u.user_colour, u.user_id, COUNT(m.user_id) as view_countCode: Select all
$user_id_member = $totalviewsmember['user_id'];Code: Select all
$view_count = $totalviewsmember['view_count'];Code: Select all
'URL' => $url,Code: Select all
'VIEW_COUNT' => $view_count,find
'MEMBER_PROFILE_VIEWS' => $member['user_member_profile_views'],Code: Select all
'MEMBER_PROFILE_VIEWS' => ($this->user->data['user_id'] == $user_id) ? $member['user_member_profile_views'] : $member['user_member_profile_views'] + 1,memberlist_view_contact_after.html
find
<span><a href="{member_viewed.URL}" "{member_viewed.USERNAME_COLOUR}">{member_viewed.USERNAME}</a></span><!-- IF not member_viewed.S_LAST_ROW -->, <!-- ENDIF -->Code: Select all
<span><a href="{member_viewed.URL}" "{member_viewed.USERNAME_COLOUR}">{member_viewed.USERNAME}</a></span> ({member_viewed.VIEW_COUNT})<!-- IF not member_viewed.S_LAST_ROW -->, <!-- ENDIF -->-
Do you mean a counter like this ?
if so its already an ext if not post a screen shot of what your edits do.
Siava
Exactly.
I have downloaded ext from the first post, but there was no counter per user.
[ Post made via Android ]
BLIZZARDCZ
Excellent nice work, big thanks
all4phone
- Donator
Polish translation v 1.0.2
uruguayito
- Donator
Hi.
After update to the last version, when I visit a profile appears this error
SQL ERROR [ mysqli ]
Unknown column 'counter_user' in 'field list' [1054]
SQL
UPDATE phpbb_memberprofileviews SET counter_user = 1, date = 1465327768 WHERE user_id = 2 AND view_id = 1783
BACKTRACE
why?
SQL
BACKTRACE
why?
Did you disable and delete data in ACP when uninstalling the "old" version?uruguayito wrote: 07 Jun 2016, 21:30 Hi.
SQL
BACKTRACE
why?![]()
uruguayito
- Donator
Disable yes...
Delete not
[ Post made via Samsung Galaxy S4 ]
Delete not
Need to delete also to get the old DB table out.
uruguayito
- Donator
Thanks so much dmzx
