Extensions Database 3.2 / 3.3 ⇒ 3.2 & 3.3 Ultimate Points Extension
NAPWR
- Donator
Re: Ultimate Points Extension
Thanks Mate
My name is Dave I, and all things are out there, and we are in here
lenz
Version 1.1.9 work perfectly.. thanks to sir dmzx for the help.
hiriu
Works perfectly on phpbb 3.2.2. Thanks from brasil.
Crajkaro
Where is the changelog for new version ?
I see this in the comment field, @ transferring points
Editing points_transfer.html seems to fix it.
Change:
To:
Change:
<dd><textarea id="comment" tabindex="3" class="inputbox" name="comment" cols="50" rows="3" >{{ COMMENT }}</textarea></dd>Code: Select all
<dd><textarea id="message" tabindex="3" class="inputbox" name="comment" cols="50" rows="3" >{{ COMMENT }}</textarea></dd>Forum voor NL Extensie vertalingen ---> https://www.supportforum.be
What style do you use?Solidjeuh wrote: 14 May 2018, 21:51 I see this in the comment field, @ transferring points
Change:To:Code: Select all
weblord
Thanks for the update/upgrade but now I have a different error. I have already cleared the cache. what do i need to do to fix it?
that is the error i got when activating the said extension.
Fatal error: Uncaught exception 'phpbb\module\exception\module_exception' with message 'CANNOT_REMOVE_MODULE' in /home/www/paidpost.nabaza.com/phpbb/module/module_manager.php:448 Stack trace: #0 /home/www/paidpost.nabaza.com/phpbb/db/migration/tool/module.php(420): phpbb\module\module_manager->delete_module(230, 'acp') #1 [internal function]: phpbb\db\migration\tool\module->remove('acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #2 /home/www/paidpost.nabaza.com/phpbb/db/migration/tool/module.php(454): call_user_func_array(Array, Array) #3 [internal function]: phpbb\db\migration\tool\module->reverse('add', 'acp', 'ACP_CAT_DOT_MOD...', 'ACP_POINTS') #4 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(714): call_user_func_array(Array, Array) #5 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(683): phpbb\db\migrator->run_step(Array, false, true) #6 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(436): phpbb\db\migrator->process_data_step(Array, Array) #7 /home/www/paidpost.nabaza.com/phpbb/db/migrator.php(351): phpbb\db\ in /home/www/paidpost.nabaza.com/phpbb/module/module_manager.php on line 448
The se_square style, updated by myself to 3.2.3 RC.1dmzx wrote: 15 May 2018, 11:54What style do you use?Solidjeuh wrote: 14 May 2018, 21:51 I see this in the comment field, @ transferring points
https://www.phpbb.com/customise/db/style/se_square/
PM me admin account and link of your board to fix it.weblord wrote: 15 May 2018, 14:10 thanks for the update/upgrade but now I have a different error. I have already cleared the cache. what do i need to do to fix it?
that is the error i got when activating the said extension.Code: Select all
weblord
I still have problems with migrator.php
Catchable fatal error: Argument 1 passed to phpbb\db\migrator::get_callable_from_step() must be of the type array, null given, called in /home/www/paidpost.nabaza.com/phpbb/db/migrator.php on line 704 and defined in /home/www/paidpost.nabaza.com/phpbb/db/migrator.php on line 726Solidjeuh wrote: 14 May 2018, 15:17 Thank you for the fix! migrator.php problem is solved now.
Installed & uninstalled without a problem!
Fixed it for youweblord wrote: 15 May 2018, 15:54 i still have problems with migrator.phpCode: Select all
weblord
Thank you very much!
yo da man
yo da man
dmzx wrote: 15 May 2018, 16:30Fixed it for youweblord wrote: 15 May 2018, 15:54 i still have problems with migrator.phpCode: Select all
weblord
What would you do if you like 8 decimal points for this? i only can see two decimal points.
