Displays AZ Menu in viewforum, in ACP selectable the forums to display AZ Menu.
Colours can be set to you personal needs.
- First release
- Unzip the downloaded release, and change the name of the folder to `azmenu`.
- Copy the `azmenu` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/azmenu/composer.json - Navigate in the ACP to `Customise -> Manage extensions`
- Look for `AZ Menu` under the Disabled Extensions list, and click its `Enable` link.
