3.2.x Extensions Database 3.2 / 3.3left menü 2.0.1
kaptangula
left menü 2.0.1
Post by kaptangula »
Extension Name:left menü 2.0.1
Author: kaptangula
  2. Unzip the downloaded release, and change the name of the folder to ` `.
  3. In the `ext` directory of your phpBB board, create a new directory named `kaptangula` (if it does not already exist).
  4. Copy the ` ` folder to `/ext/kaptangula/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/kaptangula/leftmenu/composer.json
  6. Look for ` ` under the Disabled Extensions list, and click its `Enable` link.
Re: left menü 2.0.0
Hey this has nothing to do with me :rolling: i just put it in ext format hope you changed the readme file also.
Re: left menü 2.0.0
Can you fix i cant see mchat and it stuck in the middle of my screen.
kaptangula
Re: left menü 2.0.0
Ok :tumbsyes:
ok martin update will do with css
Re: left menü 2.0.0
It would be better if it was out side of the wrap so it not in the way but close to hand.
Re: left menü 2.0.0
Not found a fix yet ?
kaptangula
Re: left menü 2.0.0
I will do
Re: left menü 2.0.0
Can i use this without mchat?
kaptangula
Re: left menü 2.0.0
You can use it
Re: left menü 2.0.0
Try the version i have on my site https://www.martins-phpbb.com/index.php
Re: left menü 2.0.0
martin wrote: 11 Feb 2019, 19:04 Try the version i have on my site https://www.martins-phpbb.com/index.php
can you give me the right link? :roll: :question:
Re: left menü 2.0.0
Link to my site ? or link to the download to the side bar i'm using ?
Re: left menü 2.0.0
martin wrote: 12 Feb 2019, 18:59 Link to my site ? or link to the download to the side bar i'm using ?
nope,left menu
also u can give me side bar you useing :thumbup:
Re: left menü 2.0.0
The side bar im using has not been released yet but it soon will be.
kaptangula
Re: left menü 2.0.1
Update has left menü 2.0.1
