3.2.x Extensions Database 3.2 / 3.3Set forum width 3.2.x
Extension Name: Set forum width
With this extension you can set forum width in ucp in pixels.
dmzx/Set-forum-width
Code update for validation.
setforumwidth_v101.zip
  2. Unzip the downloaded release, and change the name of the folder to `setforumwidth`.
  4. Copy the `setforumwidth` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/setforumwidth/composer.json
  6. Look for `Set forum width` under the Disabled Extensions list, and click its `Enable` link.
infspirit
Re: Set forum width 3.2.x
Post by infspirit »
Translate for spanish
German language file [DE]
now included in the install package.
Scanialady wrote: 20 Jan 2017, 19:29 German language file [DE]
Is added in download :wink:
Ah yes.. ok. Than I will delete the attachement
Funny
Post by Funny »
An excellent extension
Thank's
mg Funny :eusa_dance:
Tarkonte
Post by Tarkonte »
Italian (it) language here.
<?php
* @package phpBB Extension - Set forum width
* @copyright (c) 2017 dmzx - https://www.dmzx-web.net
if (!defined('IN_PHPBB'))
	exit;
if (empty($lang) || !is_array($lang))
	$lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
// Some characters for use
	'SET_WIDTH'				=> 'Imposta la larghezza del forum',
	'SET_WIDTH_LINK'		=> 'Larghezza',
	'SET_WIDTH_EXPLAIN'		=> 'Imposta la larghezza del forum. Il valore di default è 1152px.<br />Da 625px a 1800px.',
Anders
    Linux Firefox
Post by Anders »
Hi!
I have some weird things going on :rolling: i have this theme BLACK
and when i enable extension forum goes left or is this ext just for prosilver?
I put black style up at my site and the width worked in black but the forum was to the left of my page like yours.
I had to add margin: auto; in the #wrap - setforumwidth/styles/prosilver/template/event/overall_header_stylesheets_after.html
#wrap {
	margin: auto;
	max-width: {SET_WIDTH}px; !important;
Now the small 625px width forum in black style is centered in the page. The other styles did not have this problem.
Anders
    Mac OS X iPad
Post by Anders »
Sniper_E wrote: 21 Aug 2017, 03:57 I put black style up at my site and the width worked in black but the forum was to the left of my page like yours.
#wrap {
	margin: auto;
You have made My day Sniper_E
Thx
[ Post made via iPad ] Image
miri4ever
Post by miri4ever »
Is it possible to add a general width for the forum, even if logged out ? I mean guest users should also having a minimum settings of width. My forum design gets to small after logged out and with this width settings it could be fine adjusted, but first after login. Can the database having an value for visitors for a special setup width ?
I don't see why your Guest user couldn't have a width set in their user data. But they wouldn't have any control on changing the width.
And these are not minimum width settings. This extension sets the width to a user's specified setting.
The migration file sets the width for everyone when enabled to 1152px. Your Guests should see your forum at that width.
As admin you could set your Guest's view to let's say 900px with a sql command.
UPDATE `phpbb_users` SET `user_set_width` = '900' WHERE `phpbb_users`.`user_id` = 1;
With this ext installed all users will have a set width of 1152px with out the ext installed it should also be 1152px (as in prosilver)
olalavui
Post by olalavui »
Vietnamese language pack file:
<?php
* Vietnamese language pack <giaminhteam@gmail.com>
	exit;
	$lang = array();
	'SET_WIDTH'				=> 'Cài đặt độ rộng diễn đàn',
	'SET_WIDTH_LINK'		=> 'Chiều rộng',
	'SET_WIDTH_EXPLAIN'		=> 'Thiết lập này giúp bạn cài đặt độ rộng của diễn đàn, mặc định là 1152px.<br />Từ 625px tới 1800px.',
Come back phpBB with phpBBVietnam :tumbsyes:
