3.1.x Extensions Database 3.1 / 3.2Link bbCode Extension
Extension Name: Link bbCode Extension
This extension will add a download link selection box in posting template.
Add class
Use like:
[download=orange]Download-link https://www.dmzx-web.net dmzx-web.net[/download]
[download=blue]Download-link https://www.dmzx-web.net dmzx-web.net[/download]
[download=light-blue]Download-link https://www.dmzx-web.net dmzx-web.net[/download]
[download=dirty-blue]Download-link https://www.dmzx-web.net dmzx-web.net[/download]
[download=purple]Download-link https://www.dmzx-web.net dmzx-web.net[/download]
[download=green]Download-link https://www.dmzx-web.net dmzx-web.net[/download]
Link bbCode Extension v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `linkbbcode`.
  4. Copy the `linkbbcode` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/linkbbcode/composer.json
  6. Look for `Link bbCode Extension` under the Disabled Extensions list, and click its `Enable` link.
nelflucifer
Re: Link bbCode Extension
Post by nelflucifer »
Thank you! Beautiful!
English Forums
nelflucifer
Unfortunately as the extension Note, these 2 extensions don't want to work as it should with the "Advanced BBCode Box" I have the CODE to type into the text input field...
nelflucifer wrote: 09 Mar 2016, 11:22 Unfortunately as the extension Note, these 2 extensions don't want to work as it should with the "Advanced BBCode Box" I have the CODE to type into the text input field...
Try this file (unzipped) and place it in ext/dmzx/linkbbcode/styles/all/template/event
Clear cache
vse_abbc3_posting_editor_buttons_custom_tags_before.zip
nelflucifer
    unknown unknown
Thank you! Works! And for the Note extension, the same file will help?!
UP
I dropped this file in "ext/dmzx/note/styles/all/template/event/" And not helped....
samemmerde
Post by samemmerde »
It does not work
I have that I do not understand?
Can you help me ?
uruguayito
Post by uruguayito »
This extension creates a conflict with my quickly answer
I would like to have both ... any solution?
I'm a latin american man.
Spanish is my language.
samemmerde
I use File download
uruguayito wrote: 28 Jun 2016, 19:16 This extension creates a conflict with my quickly answer
Is that quickly answer an extension?
Or default?
samemmerde wrote: 28 Jun 2016, 20:13 I use File download
This should be working also
uruguayito
dmzx wrote: 28 Jun 2016, 20:38
Or default?
an ext: https://www.phpbb.com/community/viewtop ... &t=2259196 QuickReply of Татьяна5
Edit. works fine
sorry
Null
Post by Null »
Using this extension and Prime Links extension, I get this underlined text:
I would like to remove this underline but only in links using linkbbcode extension. Any idea how to do it?
Open prime links ext go to the listener.php and change the setting in there.
Null
Post by Null »
martin wrote: 12 Mar 2017, 22:27 open prime links ext go to the listener.php and change the setting in there.
But how to do it only for links in linkbbcode extension?
