3.2 & 3.3 Extensions Database 3.2 / 3.3Knuffel
Knuffel
Extension Name: Knuffel
With this extension you can add a Knuffel game to your forum Knuffel (Kniffel-Clone, also known as Yahtzee or dicepoker) is a dice game, where it's your aim to roll certain figures and reach a maximum score out of them.
- updated code for php 8.x
- Update code for 3.3.x.
- Twig update.
- Drop support for 3.1.
Made code compatible for 3.2
Code update
Added correct url
  2. Unzip the downloaded release, and change the name of the folder to `knuffel`.
  4. Copy the `knuffel` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/knuffel/composer.json
  6. Look for `Knuffel` under the Disabled Extensions list, and click its `Enable` link.
Re: Knuffel
Thanx U very much guys :buigen:
Knuffel will not start, problem with the dice ?
Peralta
Re: Knuffel
Post by Peralta »
Thanks, i like this game :thumbup:
It will add support in responsive mode?
Re: Knuffel
Problem Solved thanx to dmzx :tumbsyes:
ext\dmzx\knuffel\controller\main.php
			'KNUFFEL_VERS'		=> $version,
      $board_url = generate_board_url() . '/';
Re: Knuffel
Peralta wrote:Thanks, i like this game :thumbup:
Yes need to check on that :wink:
Re: Knuffel
nelflucifer
Re: Knuffel
Post by nelflucifer »
Hello everyone! As I promised, post the translation(s):
ru.zip
Very interesting game...
English Forums
sile
    Mac OS X iPad
Re: Knuffel
Post by sile »
Thanks for this Game i Love it :dance:
[ Post made via iPad ] Image
all4phone
Re: Knuffel
Post by all4phone »
Hi, thx for great ext :tumbsyes:
At the moment I'm working on translation and I have a little problem. I try to translate all messages and descriptions of buttons from a "Roll dice" window, such as: "2nd throw, Final throw, Next round" or "Enter your score!".
I can translate all the required language strings wich are located in knuffel260.js file of course.
What about others languages? Do you know what I mean?
Re: Knuffel
all4phone wrote: 02 Jun 2016, 21:06 Hi, thx for great ext :tumbsyes:
Only translate the EN language and it will be ok.
all4phone
    Mac OS X Android
Re: Knuffel
Post by all4phone »
I mean about two or thre languages used on the one board :wink:
[ Post made via iPhone ] Image
Re: Knuffel
all4phone wrote: 02 Jun 2016, 21:15 I mean about two or thre languages used on the one board :wink:
I dont know what you mean, languages in the extension?
all4phone
Re: Knuffel
Post by all4phone »
Yes, usually extension has to be translated into several languages.
Let me explain what I mean.
For example: first user has use english language and the second has to use polish language - both users on the same forum/board, on which you can choose your language.
In the ext/dmzx/kneffel/language, there are (for eg.) two language directory (en, pl). It's fine.
But what about ext/dmzx/kneffel/knuffel/script/knuffel260.js file, that contains language strings also (mentioned above) ?
I think, in that case, when Polish-language user will be playing Kneffel, he will have a little bit english language in this game.
Or vice versa, when extension will be translated to polisch language only (I mean knuffel260.js file) then English-language user will have a little bit polish words.
Re: Knuffel
Yes see what you mean, best would be in JS that it detects the PL language. same as DE now.
Need to think about it.
forza sve
    Ubuntu Firefox
Re: Knuffel
Post by forza sve »
Hi dmzx,
thx for this great extension.
My Question. We have only a few players at the Knuffel-game. To make the game more interesting for our players, we want to display the best 10 or 20 results in the highscore. So the players can try to place many of his own results in the top ten. Is that possible? (phpbb.com)
